06-30-2005, 06:44 PM
AC cuts off
My AC cuts off. I am plugged in to shore power which has 30AMPS but when I turn the AC on, it runs for 4-5 seconds then the breaker is set off. (The one in the bedroom) I reset it, then all works fine.
This happens even when all appliances are off, including fridge, univolt, lights.
I requested a resolution to this and they said they would look at it and suggested I may have a problem with the breaker? Is that possible? From this it seems the breaker is working as designed?
I doubt it's the problem on my end because the last CG I was at I could run my AC/fridge/univolt with no problems and the AC works well and cold. I don't know how many Amps they had. How do I communicate this problem to the maintenance people and how do I prove it's not a problem on my end (or resolve it if it is)
I can only use the fan option in the unit and it's a boiling 97F inside...
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
06-30-2005, 06:55 PM
1999 25' Safari
Manchaca
#1 I would suspect carbonized contacts on the park 30A outlet - the larger the load, the greater the voltage drop / current increase.
If you have a voltage meter in your trailer you should see a significant drop when the AC compressor kicks on.
#2 - maybe there really isn't 30A available due to high demand at the park
WBCCI 1845
06-30-2005, 06:56 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
check this thread: http://www.airforums.com/forum...lowing+breaker
I had lots of corrosion on the wires and the bus bar in the breaker box. luckily, the breaker did work, and prevented a fire. but things got hot enough to toast the insulation on the wires.
the corrosion caused more resistance in the wiring, as all that juice was trying to squeeze through, which causes heat, which caused the breaker to pop. the box was hot to the touch, too.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
06-30-2005, 09:58 PM
The outlet looks bad. It's cover fell off some time ago (months) and it looks pretty rusty. Also it looks like it's pretty old, years if not decades. Do you think that's part of the problem?
I have a Voltmeter, but how do I use it to check the Amps? at that outlet?
That's another concern... How do I throw the ball in their court so that they don't say it's on my end? Like I said, my appliance worked perfectly just last summer - at another CG. I strongly suspect there is something wrong on their end.
But I read the thread about corrosion in breaker boxes. This winter I've had real high humidity inside the camper, could this have caused some corrosion in my breaker box? How do I check? I need to narrow this down and resolve it.
07-01-2005, 03:41 AM
1967 26' Overlander
Huntsville
, Alabama
Voltage check for power quality
Most multimeters can not measure AC current, so the only thing you can do is verify good voltage.
Air conditioners prefer to see between 115 & 120 volts on the line to run properly. Anything below 105 volts will probably end up cooking your compressor.
I agree - The campground may not be able to supply you with 30 amps at 120 vac.
The easiest way to verify this is to plug your voltmeter's probes into the CG's 20 amp outlet, and check the voltage before and after your air is on. For comparison, then plug the voltmeter into one of your interior outlets, and repeat the above. Anything below 115 vac (other than a brief spike when the compressor kicks on) indicates poor power quality.
BTW, breakers do go bad. Sometimes the points weld together (worst case), and sometimes they open too soon (your case). You could very well have a weak breaker.
But check your voltages first.
Tom
07-01-2005, 07:06 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
you simply take the cover off the box and look for rusty stuff.
But from your description, it sounds as though the campground's outlet is the culprit.
Air:291
Wbcci: 3752
'73 Safari 23'
07-01-2005, 05:15 PM
I pulled the amps on the outlet and it looks like its getting 18.5Amps. Not enough to run the AC apparently. The older units as I understand had higher amps requirements than newer ones, and this one is 20 years old. It's very rusty as you can see.
07-01-2005, 05:30 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
I don't think you are checking the amps. To check amps you have to be in line with the load or have a special meter and clip that goes over the wire while under load.
You need to check the AC voltage as described above.
However; if there is another campground box close by (25 ft or so) you could try another outlet.
Garry
07-01-2005, 05:41 PM
The CG told me they would replace the breaker box so that all may be irrelevant...
Hard to say what's worse, being without heat in the winter or without AC in the summer.
07-06-2005, 08:09 PM
They say they replaced the breaker in the outlet but my AC still cuts off after 5-7 seconds. They say the problem is on my end. What do I do to confirm/deny this? (It's turning into an emergency because it's very hot here)
07-06-2005, 08:42 PM
Retired.
, At Large
Did they replace the breaker, or the breaker and plug?
If they just replaced the breaker, and the plug is still corroded and not providing a clean surface for your plug, you will still have a massive voltage drop going to your trailer. Using your voltmeter shown in your previous post, set it to AC Voltage, 500 volt range, and plug the leads one into each flat recepticle of an outlet in your trailer. Check your voltage, you should have at least 120 volts at an unloaded plug. Then, leaving the voltmeteer plugged in, and on, turn on the air conditioner. If the meter takes a dive to 80 volts or so, you have a bad connection, or a bad compressor. I am guessing you would know if your compressor was bad enough to make that kind of voltage drop. It would be groaning and growling, and the whole trailer would be vibrating.
If the voltage doesn't drop below, say 110 volts, you have either a bad connection between your breaker box and your A/C unit, or the A/C is bad, and requires repair or replacement.
07-07-2005, 11:53 PM
Terry,
I agree with your meter connections advice, but I disagree with your analysis.
If the voltage drops to 80 volts or so, as I suspect it does, this does not necessarily mean those problems alone. It can still be a problem with the shore power.
Just because the receptacle is rated at 30 amps does not mean that the wiring to the receptacle is adequate for 30 amps, especially when many other campers are also using power from the same main wire. It is quite possible that the voltage drop is due to inadequate supply to the receptacle.
Ipso,
Proper troubleshooting of this problem requires a knowledge of meters and how electricity works. You may also have to buy a clamp-on ammeter (either a separate meter or an accessory for your multimeter) and a length of 30 amp cable that has been taken apart to allow a reading on only one conductor in that cable. Most multimeters will not measure 30 amps.
The easy check for problems is the voltage check that has been suggested in various forms earlier in this thread. If the voltage drops dramatically as the air conditioning unit attempts to start, then the most probable cause is inadequate power supply, since you said your unit worked last year at a different campground. My guess is that the inadequate power is caused by an undersized (for the total load) supply to the receptacle. The resulting low voltage is causing higher than normal amperage through the air conditioning circuit and the breaker is tripping.
Volts x Amps = Watts
or
Electric potential times current equals power.
Your airconditioning requires a certain amount of power to start. If the voltage drops, it will demand higher amps.
The ultimate test (after checking voltage as discussed earlier) is to connect an ammeter in the trailer's shore power cord. If this cord is not getting 30 amps (or whatever the air conditioner demands when it starts), then the problem is on the campground side, not yours. If the receptacle is supplying 30 amps at 120 volts, then the fault is on your side.
Good luck.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
07-08-2005, 12:08 AM
1984 29' Sovereign
Savannah
, Missouri
After looking at that picture of your CG's outlet box, my only question is:
WHY ARE YOU STILL THERE???
I'd be out looking for another CG so fast, it would make your head spin.
Just my humble opinion~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
07-13-2005, 06:59 PM
overlander63,
they just replaced everything, the breaker, the plug. They checked the voltage it's 120V before and after the AC is turned on. The problem is on my end.
What can I replace? Should I start with the breaker? Is it difficult to remove? Where do I get the replacement, does Home Depot has them? and what's the right size?
07-13-2005, 11:08 PM
a/c
could it be the contacts on your a/c switch? if you hold the swich down will it stay on? coul be you just need a new a/c unit?
07-14-2005, 07:45 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Ipso: did you check the link that I posted earlier? take the cover off your a/c panel, and look....if you see rusty stuff and/or green gunk (corroding copper) all over the place, that's probably your problem. you'd need to go in there to replace the breaker, anyway. and yeah, they have them at HD; its a regular household circuit breaker, just like you might have in your house. my trailer has 2 20 amp circuits: one is dedicated to the a/c, the other runs everything else.
Air:291
Wbcci: 3752
'73 Safari 23'
07-14-2005, 10:11 PM
The last place we stayed at the voltage was 109 and it did blow the 30 amp breaker.
I cleaned the plug and the socket contacts and splade the pins for a better purchase.
Ii never blew the breaker again
07-16-2005, 10:33 PM
That's it.... I replaced the breaker, which was the problem, as it turns out and the AC does not cut off anymore.
However, I think the compressor is going out. It's just blowing air which isn't cold. I think this is the original, 20 year old unit, so I suppose it did good, considering there is only a 2 year warranty on these Colman units.
Any idea if the above is true, and if so, what's a good place to get a Colman AC unit? Is it possible to find a used one?
07-16-2005, 10:46 PM
you may just need freon? expensive,but cheaper than a new unit. you can have it converted to a new coolent for less than $100 and the new coolant is only a few bucks a pound instead of $30 per pound.
07-17-2005, 08:44 AM
I had the same thought actually.
But what if I add the freon and it leaks out then it is a waste of money. I had that happen to a fridge.
