Old 09-24-2023, 11:44 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
AC Cooling Fine However
The AC is cooling fine however when running it is making a whining noise inside the AS that I have not heard before. Does anyone have any idea what might be causing it.
urnmor is offline   Reply With Quote
Old 09-24-2023, 11:53 AM   #2
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Brenham , Texas
if it is cooling and making a whining noise, I would suspect fan motor. try running just the fan and see if the noise still occurs. at least that will help you narrow down the problem.
dbdreams is offline   Reply With Quote
Old 09-25-2023, 07:54 AM   #3
urnmor's Avatar
Berlin , Maryland
Thank You
I did what you suggested and I do believe it is the fan making the noise. Do you have any suggestions on how to reduce the noise.
Old 09-25-2023, 08:19 AM   #4
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
be sure to check all the intake and exhaust vents and that they are free and clear. remove the grates and check for loose objects
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
waninae39 is offline   Reply With Quote
Old 09-25-2023, 11:04 AM   #5
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by urnmor View Post
Thank You
I know of 3 people that tried lubricating the fan bearings and had the fan motor seize and need to be replaced in under 2 weeks. Also know someone that has been putting up with the whining for 3 or 4 years. From this your 2 options seem to be put up with it or replace the fan motor.
Old 09-25-2023, 02:03 PM   #6
CAB & DAB
dbdreams's Avatar
Brenham , Texas
URNMOR,
IF you are comfortable climbing on top of your airstream you can remove the shroud and check a few things on the fan. 1, turn off the air conditioner and kill power to it. Maybe unplug the trailer to make sure power is dead. 2nd make sure the 3 fan motor mounts are tight, many times the wellnuts loosen allowing the fan motor to shift slightly and letting the fan rotors touch the housings. There are a few youtube videos on this. spin the fan by hand and see if you can determine where the noise is coming from. Any dometic technician would also know where to look if you don't want to climb on the roof.
Old 09-25-2023, 02:05 PM   #7
CAB & DAB
dbdreams's Avatar
Brenham , Texas
By the way, fan motors are about $250 and it takes about 30 minutes to change it out, 45 minutes with a coffee break!
Old 09-25-2023, 04:48 PM   #8
urnmor's Avatar
Berlin , Maryland
Thank you I might remove the shroud and and check after looking at the videos and the weather clears up. If necessary I will replace the fan as a last option.
Old 09-25-2023, 05:44 PM   #9
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
There have been some cases of fan bolts coming loose causing noise and vibration the ac cover has to me removed to verify
Life is a Highway is offline   Reply With Quote
Another fine trip.. Safari Tim On The Road... 1 06-23-2007 11:13 AM
Refridgerator was working Just Fine,...til I started messing with it MileHigh Refrigerators 2 06-12-2004 01:56 PM
Fine rates on the Interstate Silvertwinkie Off Topic Forum 7 03-08-2003 07:46 AM
Load Leveling Hitch Fine Adjustment Road Ruler Hitches, Couplers & Balls 1 02-23-2003 12:32 PM
