Old 06-26-2022, 01:02 PM   #1
2018 27' International
AC condensate drain
I have a 2018 27FB International with two ACís. The AC above the bedroom (front of trailer) is not draining through the condensate tube. It collects on the roof and drains along the side of the trailer. I suspect the drain line got disconnected from where it connects to the AC. Does anyone know exactly where that is? Do I need to disassemble much of the AC beyond maybe the cover to find? Hoping it isnít something stuck in the drain somewhere; that might be impossible to fix.
Bright67 is offline   Reply With Quote
Old 06-26-2022, 08:34 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Actually something stuck in the drain line is much more common and easier to fix. Easiest fix to try is blowing compressed air up drain line, next is shove string trimmer line up drain line.
Old 06-27-2022, 07:19 PM   #3
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
If you remove the grill in the ceiling, you can see the drain line and connectors. I had a bug stuck in my rear AC line. When I blew mine out with air, I disconnected line in ceiling and blew out through wheel wells.
StuartsDad is offline   Reply With Quote
Old 07-01-2022, 06:19 PM   #4
Thanks for the tips. I’ll give it a try.
Condensate Drain Question khollister Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-15-2016 05:05 AM
A/C condensate drain tube? Gearheart All Argosy Trailers 3 07-02-2014 10:29 AM
replacing condensate drain tubing wmarsha Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-28-2009 06:39 PM
Condensate Drain mkeith54 All Argosy Trailers 3 08-18-2003 02:01 PM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 07:05 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
