Old 05-28-2024, 03:01 PM   #1
2018 26' Flying Cloud
Oriental , North Carolina
AC blows hot air
I am having a problem with my 6 year old Dometic 15k heat pump. I keep my Flying Cloud 26U inside a metal building in the winter. I set the thermostat at 50 degrees. We made a trip in late February and the heat pump worked nicely. But, this Spring I found my unit will not cool. Instead of cooling, it blows hot air. It’s like the unit is stuck in heat mode even though the thermostat says “Cool”. So, the first thought is a stuck reversing valve. Or maybe a bad valve relay. I would assume a reversing valve could be replaced, but I read discussions which lead me to believe that is either not possible or very costly. Has anyone had this same problem, and if so, how was it resolved?
Captn.Ken is offline   Reply With Quote
Duotherm AC blows hot not cold RichHog Furnaces, Heaters, Fireplaces & Air Conditioning 50 11-16-2024 03:48 PM
Furnace blows hot, then cold. What gives? trekerboy LP Gas, Piping, Tanks & Regulators 52 10-19-2015 10:57 AM
furnace blows cold air only 99Limited34 Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-08-2010 09:49 PM
Furnace blows cold air guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-06-2007 11:26 PM
