Old 06-04-2023, 04:14 AM   #21
2016 25' Flying Cloud
z , Texas
Originally Posted by TankerIP View Post
After reading 5050MIke's reply I understand some of the problem. The temp sensor for zone 2 (living area) is located directly behind and affected by the temperature of the TV. Our TV is on. Using my IR temp gun the temp on the sensor cover was 82 -- on the thermostat it showed 78. But the wall temp below the TV was 72. This is a 6 to 8 deg error. The TV itself was hot at 84 and affecting all the surrounding area above the TV. Now in Zone 1 (bedroom) where the TV was OFF, the thermostat said the temp in the room was 71, and the wall temperature was measured also at 71. This seemed an accurate reading. So bottom line is that the temperature sensor needs to be moved to somewhere other than directly behind the TV.
Another issue I noticed was when running the zone 1 (bedroom) A/C alone. I could feel cooling air was coming out of the Zone 2 intake vents. It seems to me that the intake vents need to be isolated from the distribution duct so that intake and outflow air is not mixed. I'll have to check in to this closer to verify. Anyone else notice this?
I wonder if Airstream can make modifications and fix this since I am still in warranty?
TankerIP
Did you ever figure out why air was coming out if the intake in zone 2 when running zone 1 ?
5150mike is offline   Reply With Quote
Old 06-05-2023, 06:25 AM   #22
TankerIP's Avatar
2002 22' International
2019 25' Flying Cloud
A common duct system
Originally Posted by 5150mike View Post
TankerIP
I think it's a common duct system. At first I was concerned. Then after having to camp in spots with only 30amps I realized I was able to get a good amount of cooling going through the trailer with only the one A/C. So we just got used to it.
TankerIP is offline   Reply With Quote
time zones ??? MikeL Forum Admin, News and Member Account Info 4 02-20-2021 07:52 AM
AC Zones Swapped Overstreet 2016 - Current Classic (all lengths) 1 07-08-2020 04:02 PM
Heat/AC Zones? journeydog Shhhh... Coming soon 3 12-23-2017 11:47 AM
Difficulty Controlling uniform heat/cool temps between zones 1&2 zapper 2016 - Current Flying Cloud 17 09-12-2017 09:18 PM
Route Planning and Construction Zones CanoeStream On The Road... 7 06-01-2007 07:33 AM
