A/C Leaking from drain in pan at outlet
Hello all,
Have been lurking for some time getting helpful info. Having MAJOR problem w/2000 34' with the 'original' type of drain pan under the AC.
Problem is that here in S (FL) very humid and after about 5min, starts to leak water from the filter area of the inside shroud. Wife is up in arms about carpet getting wet.
Took down shroud today to see if I could find source. Found problem, however, am trying to figure out how to fix WITHOUT taking AC off roof and replacing pan. It has fractured around the area that the drain outlet is in, the nut holding fitting in has come off, and it is VERY tight in the entire space.
Thinking about getting a piece of plastic, drilling hole that fitting would fit thru, and using a BUNCH of RTV to glue the plastic in-place. BTW, the fitting is METAL
I know that the BEST fix is to remove AC and replace entire pan, however, there is not an Airstream repair for 200 miles and getting in would take forever. I cannot get up on top w/ladder, unfortunately.
Thanks in advance to all,
Lawrence
