Old 06-08-2024, 09:47 AM   #1
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
A/C Help on '58 Traveler
As the title states I have a 1958 Airstream Traveler and considering installing an Air Conditioner. Typically we travel more in the winter but when I sell our motor coach that may change.
I read here that I will need to reinforce the roof in the area of the vent but cannot find that post, any help would be appreciated.
Also wondering if anyone has moved the vent because I do like Dry Camping.
Thanks in advance!
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 06-08-2024, 10:10 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: A/C Help on '58 Traveler
Greetings Steve!
My suggestion would be to contact customer support at the factory and ask if there is a preferred spot to cut the opening for a roof mounted air conditioner on your 1958 Traveler. When the air conditioners became factory options on Airstreams, they were cut into the roof in a location other than an existing vent opening so there is a document available that lists the distance from the number one (front) bow to cut the opening for the air conditioner. The document that I am familiar with covers most of the 1960s, but there may also be standards for the 1950s models as well.
Out of Doors Mart offers an air conditioner install kit with the necessary hardware to reinforce the opening for an air conditioner. They list it as out of stock at the moment, but it would be worth contacting them to see when it may be available again.
Good luck with your project.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 06-08-2024, 10:58 AM   #3
1966 22' Safari
Fredericksburg , Texas
Steve, glad to see that you havenít retired from the Airstream world.
Bubba L is offline   Reply With Quote
Old 06-09-2024, 07:02 AM   #4
1958 18' "Footer"
Back at ya! how are you guys doing?
You haven't missed much at Pismo (spring) attendance has gone down.
Steve
Old 06-09-2024, 07:05 AM   #5
1958 18' "Footer"
overlander64;
I will look into that but I was told that the proper location would be where the vent is.
I saw a different post where it was reinforced with a wood framework and that is what I would like to find.
Steve
Old 06-09-2024, 02:34 PM   #6
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Vintage AC locations
Reinforcing what Overlander64 said. There is (used to be) a chart of recommended AC install locations. It is possible Out of Doors Mart has it as well. Most times the vent was the spot but that is not an absolute.
cbburke is offline   Reply With Quote
Old 06-09-2024, 03:38 PM   #7
1960 26' Overlander
Tipton , Iowa
I hate to disagree with the person that told you that the proper place for the A/C is in a vent opening. When my grandfather first got an A/C in his (now my) 1960 Airstream (back in the early 1970's) he took it to the factory. They did NOT use one of the 3 available vents on his Overlander, but made a separate opening for it between the rear two vents! While it is an option to use a vent opening, it is one that in my family's experience is not the factory's preferred location. I too appreciate being able to open the vent instead of relying on the A/C all the time.
Scott S is offline   Reply With Quote
Old 06-09-2024, 04:40 PM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The opening basically just needs to be in between two middle ribs and that does not interfere with any interior furnishings. With an 18 ft Traveler you don't have a lot of topside real estate available, so an existing vent may be your only option. I put my AC on in between two existing vents on my 21' Globetrotter and there was really only one choice for its location.
Old 06-21-2024, 10:04 AM   #9
1958 18' "Footer"
Has anyone tried any of the 12 Volt DC ones designed for vans?
Steve
Old 06-21-2024, 11:06 AM   #10
1966 22' Safari
Steve, take a look at the Nomadic S1 mini split for vans. Thereís a guy in Austin thatís going to order and install one in his 22 foot Airstream. I read the online manual and have some questions. Just a thought.
Old 06-21-2024, 12:10 PM   #11
rideair's Avatar
PLEASE, Please, please do not put an AC on top that trailer.
I would suggest looking at this thread, my post #15 will show you a quick, easy way to have AC (when you need it)
https://www.airforums.com/forums/f42...nit-41052.html
If you have question please message me and I’ll walk you through the process.
Paul Waddell
rideair is offline   Reply With Quote
Old 06-22-2024, 08:55 AM   #12
1958 18' "Footer"
Originally Posted by Bubba L View Post
Steve, take a look at the Nomadic S1 mini split for vans. There’s a guy in Austin that’s going to order and install one in his 22 foot Airstream. I read the online manual and have some questions. Just a thought.
Don't have room on the outside for a split unit. With my spare tire & propane tanks there isn't any room left.
Have you looked at their 12 Volts DC units that fit the opening?
Thanks for the thought
Steve
Old 06-22-2024, 08:59 AM   #13
1958 18' "Footer"
[QUOTE=rideair;2740286]PLEASE, Please, please do not put an AC on top that trailer.
Sorry but that is not what I am looking for. Rather have something more permanent since I live in Southern California. Thanks for the thought though.
But.. still not sure what I am going to do. As soon as I sell the motorhome then it will become more necessary.
Steve
1958 Traveler 18 FT Traveler carscox Airstream Classifieds 1 07-26-2020 12:05 PM
traveler :: 1960 Airstream traveler mvperini Airstream Registry Discussions 0 01-26-2013 01:23 PM
Wiring help with 1958 Traveler prairieschooner Electrical - Systems, Generators, Batteries & Solar 2 09-23-2006 03:26 PM
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
59 Traveler bkpine 1959 Traveler 8 11-11-2002 10:31 PM
