Old 04-08-2017, 04:50 PM   #1
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
A/C help
I have a Mach 8 13.5 BTU. Today every time I turn it on it pops the breaker. Any suggestions?
Cristobal is offline   Reply With Quote
Old 04-08-2017, 04:52 PM   #2
Lakes Region , New Hampshire
Pop the cover of the roof unit and make sure everything spins freely and is clean
RandyNH is offline   Reply With Quote
Old 04-08-2017, 04:53 PM   #3
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
It does. I just went up there and checked. The unit is only three years old. I guess do I take it to camping world and let them check it out?
Old 04-08-2017, 05:09 PM   #4
Chelsea , Maine
No. Anywhere but CW.
It might be a good place to buy stuff, but they shall never approach my possessions bearing wrench nor screwdriver.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 04-09-2017, 10:08 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
A/C help
Sounds like your start or run capacitor may have bit the dust. Hop up on the roof, remove the plastic AC shroud / cover and look for 2 small cylindrical devices with wires attached at one end. If one of them is bulging, split, burnt or exploded ... then you have found your problem. $10 part and DIY replacement.
wulfraat is online now   Reply With Quote
Old 04-11-2017, 06:07 PM   #6
Cristobal's Avatar
1988 34' Limited
Brunswick , Georgia
Ok. I know the owner of the local RV repair place here in town. He said make sure all the motors move freely and so on. I did that. I noticed that the breaker requirements say 20 amp min and 30 amp max. I put a 30 amp in and when the compressor kicks on you can tell it's struggling. The fan slows down and it seems to cycle more often. I think the compressor is going bad. That being said. Do I stick with a Coleman Mach 8 or use a different brand?
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
