Old 07-21-2020, 06:38 PM   #1
Marston , NC
A/C electrical?
My AC unit is a Dometic Duo-therm RV A/C Model No. 57915.532. For the two years that I've had my trailer, it hasn't had a problem, but starting maybe 2-3 months ago, it started to trip its circuit breaker.
The power box routes all power through 3 separate dual breakers, for 6 switches total. The culprit breaker here is the 30/20 breaker, with the 20 amp switch being the AC power, and the 30 amp being the main power switch.
At times, the AC switch trips and shuts it off. However, some times it is the main power switch that trips, which shuts the entire trailer off.
I need to know what the cause is, so that I can avoid the cost of a diagnostic. Bear in mind that I have zero experience with AC systems.
QuilavaMan is offline   Reply With Quote
Old 07-21-2020, 08:41 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds like a power input is place to begin. What is condition of the plug and cable?
What is your level of Electrical experience?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-21-2020, 09:42 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You very very likely have a bad start capacitor on your air conditioner. They go bad it happens.
The start capacitor stores energy and acts as a “shock absorber” when the AC compressor starts so it doesn’t draw / spike with totally crazy currents to the breakers.... They cost about $20 bucks. You can google “how do I replace a capacitor in my RV air conditioner” for videos.
If you are not comfortable getting on the roof and working on the unit and potentially electrocuting yourself messing around with 120v components I’d call a mobile repair service. Will cost you about $150 bucks to fix the problem.
Personally I’ve done it and it’s not a big deal to replace.
wulfraat is offline   Reply With Quote
Old 07-22-2020, 01:12 PM   #4
Marston , NC
Unfortunately, I have zero electrical experience. And to make matters worse, the panel on the capacitor is faded, so there is no way to really obtain accurate information about it.
Old 07-22-2020, 02:33 PM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you find the wiring diagram for your AC? It might be on the unit. There is a chance that the capacitor specs may be on the wiring diagram. A decent multi-meter has a capacitance test function and can give you an actual value. Not hard to check, specs needed to compare readings to specs.
How old is your unit?
Gary
GCinSC2 is offline   Reply With Quote
Old 07-22-2020, 03:45 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Probably safest to call an RV tech at this point...
Channing
WBCCI# 30676
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 9 02-05-2019 06:38 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 08:53 AM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-18-2002 11:47 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
