Old 05-08-2018, 10:53 AM   #1
Kyoshi's Avatar
2015 28' International
Beachville , Ontario
A/C Drain Plugged
While in Florida this winter, the AC ran a lot and we noticed dripping coming thru the seam over the dinette table. Called the Dealer back home (CanAm) and they said that it was probably the AC drain plugged or partially so. That water inside roof would not be a problem and could get it looked at when I got home. Of course the AC has to come off for repair. Anybody else have this problem. I have a 2015 28 ft International Signature RB.
Kyoshi is offline   Reply With Quote
Old 05-08-2018, 06:34 PM   #2
2006 25' Safari SS SE
Alfred , Maine
We had a similar problem with our 2006 Safari. Dealer had to take down the whole inside wall and found an 1/8" hole in the top part of the drain tube. It appears they drilled too deep for this one rivet and got the hose. We are the second owners and it didn't leak before or it just wasn't noticed. Dealer believed there wasn't enough water from the a/c for it to over flow from the top until now. Very hot day and a/c was working very hard. Airstream denied it was their fault. About a 10 hour job. Hopefully this isn't your problem.
Annarog is offline   Reply With Quote
Plugged into 110, lights still drain the batteries. 1Bombshell Batteries, Univolts, Converters & Inverters 7 12-12-2020 06:29 AM
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 02:14 PM
Ugh! Plugged Black Water Drain JBBeaubeaux Waste Systems, Tanks & Totes 19 01-09-2017 01:32 PM
Battery drain while plugged in. Jfuller678 Electrical - Systems, Generators, Batteries & Solar 9 05-15-2013 08:51 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
