Old 06-02-2021, 08:21 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
97-100 degrees in MInnesota
We have a camping trip planned this coming weekend with some friends. It looks like temps are going to be in the upper 90’s & humid all weekend. just an FYI, we had lows in the upper 30’s this past weekend...gotta love MN! We have a 2021 FC 30Bunk with both 13,000 & 15,000BTU A/C’s w/Dometics version of the Easy Start. Unfortunately, when I reserved, 30amp was the only available option. I’ve heard it is possible to run both A/C’s off of 30amp by pre-setting the 15k very low. Then starting the 13k, once the 15k is up and running. Is this accurate? Anyone out there with good experience doing this? I plan to run my fridge on propane and no lights during the day. The temps drop into the 70’s at night, planning on running only the 15k at that time.
- Stewart
s1000pre is offline   Reply With Quote
Old 06-02-2021, 09:32 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Unless thinks have changed over the years, my 15K unit uses between 18-20 Amps of power The variance being whether the unit is running on high cool or low cool. If you are going to be camped under shade, I dare say the 15K unit should be comfortable. With awnings deployed all around, I've never been in a situation where I've considered my single 15K unit to not be able to keep things comfortable. Now if I was in the deep south I probably would have had a second unit, but I've been in the upper 90's with no discomfort. I have blown 30 amp breakers at campsites however when the fridge and water heater are on electric, and the air is running full tilt. At that point firing up the microwave will press the limits of some site 30 amp breakers.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Victron 100/30 vs Victron 100/20? smsasf Generators & Solar Power 0 08-04-2020 07:09 PM
It’s 100 degrees and the AC quit! Ktholin Furnaces, Heaters, Fireplaces & Air Conditioning 16 08-31-2019 06:48 PM
how can I get a RV fridge to cool in 100 degrees F? nmeyer Refrigerators 15 07-29-2010 09:10 AM
Frig at 72 degrees, needs to be level ??? wagnerda Refrigerators 18 01-20-2008 05:00 PM
Sweet 16 (degrees) and all's (mostly) well Antique Pedaler Our Community 1 03-04-2007 09:56 PM
