12-26-2020, 10:01 PM
2021 27' International
City
50amp dual AC option
Hi All - We're looking to sell our 2020 Bambi 20' FB (will be posted on the sale forum soon) and go with the 27 FB international with the bunk option (growing family, need more space!). I wanted to see how necessary it is to have the dual A/C option. We do a fair amount of boondocking, and only run the a/c if hooked to shore power currently. I'm mostly wondering if the one a/c wouldnt be powerful enough to cool the whole trailer even if the vents are closed on the other side. Thanks for the advice!
12-26-2020, 10:08 PM
2013 27' FB International
El Dorado Hills
The answer depends if you plan to camp in south Texas or Leadville Colorado during the summer.
12-26-2020, 10:44 PM
City
So lets say we do camp in Texas in the middle of summer with 100% humidity...would one a/c keep it below 85 degrees or nah
12-26-2020, 10:56 PM
2007 22' International CCD
Corona
Data point. Actual test run of our 22’ 2007 International CCD with one air conditioner in the heat commenced at 11:30 in El Paso Texas, September 2019. 98 degrees and 98 percent humidity outside.
We were running on a Champion 3400 inverter generator on propane from the Airstream propane regulator. Generator sitting in the truck bed. Genset engine running a bit above idle after short warmup on economy mode. Full sun exposure. One dinette shade opened to see outside. All vents shut.
Two humans and four small dogs aboard. Cranked AC on full speed blower for about 20 minutes to get to a more or less comfortable 75 degrees maintained inside for about two hours.
Personally I would go with two air conditioning units on a bigger Airstream for redundancy. If one quits you have a fallback position on a 27 footer. I’d put MicroAir EasyStart units on both of them so a 3400 watt inverter could haul both of them at the same time.
12-26-2020, 11:30 PM
2018 28' International
Fayetteville
, Georgia
Get the 59 amp/dual AC. Having 100 amps system capacity allows you to run both AC’s and hot water and the microwave, etc. And you will be cooler.
brick
2018 International Serenity
Cute wife...
12-27-2020, 04:36 AM
2021 27' Flying Cloud
Salado
We purchased our 27' FC a couple months ago from the Austin dealership. According to my salesman, they always order dual HP units unless the customer specifically and against their recommendation requests a single HP unit. They do this for cooling in the Central Texas summer.
12-27-2020, 05:04 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
Two is one and one is none.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
12-27-2020, 06:29 AM
2015 25' Flying Cloud
Redmond
We have one AC on our 25' and wish we had two when camping in the summer. We are in Arizona which is like camping in a toaster sometimes, but the one AC works hard for less than ideal cooling. And like others have said, you can always get the dual AC and just use one if that's all you need. I'm a big fan of having options.
12-27-2020, 06:37 AM
2018 27' Globetrotter
Mooresville
, North Carolina
We were in Big Bend Nat'l Park mid-Oct, 2019. I can't remember how hot it was during the day but 80 degrees at 10:00 pm. We have a 27' Globetrotter with dual A/C's. Set the thermostat at 80 with both running and they never shut off. The 50 Amps is a big plus as well with a family.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
12-27-2020, 08:42 AM
2023 27' Globetrotter
Williamsburg
, Virginia
Two is better, as Acheron says. Plus, will likely help your resale down the line.
12-27-2020, 08:48 AM
2021 33FB Classic
2019 30' Flying Cloud
Katy
Running continuously, 1 AC unit will be able to lower the temperature in that trailer by about 15° to 20°F in the sunny, hot, humid South Texas afternoons.
But I think you're asking the wrong question. Humidity level is much more important for personal comfort than is absolute temperature. We find it took 2 AC units to get things really comfortable inside during the daytime.
A single unit is quite adept at nighttime cooling, although we still needed 2 to get down to our perfect sleeping comfort levels.
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
12-27-2020, 09:34 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Data point:
One AC running on a 30'. 95 on the weather report. Closer to 105 out in the sun in the parking lot. No wind, no awnings out. All the shades drawn. Never made it below 85 (and 100% RH indoors) all day long.
Welcome to New Jersey in June.
Since then, as long as there is shade / breeze and the humidity isn't up around 100%, things work pretty well.
12-27-2020, 09:43 AM
2015 25' FB Flying Cloud
Huntley
We ordered dual 27 fb serenity 2018. Never regretted. In Iowa 94 with 90% humidity a life saver. Note! We had to remove the vent covers. With both ac going we were still 90 degrees. Took off vent covers and temp dropped 15 degrees in 10 minutes Put our old screen vent covers back on. The covers we had just obstructed the airflow.
12-27-2020, 09:53 AM
2019 27' Globetrotter
McKinney
A/c
As someone who was born, raised, lives and camps in Texas, I will tell you that the having the duel A/C’s is not an option but a must have.
12-27-2020, 09:57 AM
2019 25' International
Providence
, Senior Electrical Engineer
Dual airs here in a 2019 for only 2 people in Rhode island...we like it around 71F and both do that efficiently and allows ACs to recover. Get 2, you won't regret it.
12-28-2020, 08:54 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Recovery is indeed an issue.
You pull into someplace with a trailer at 110 degrees inside. The family wants to get this or that going. With one A/C and 100 degrees / 95% RH in the full sun .... a single isn't going to do much good. You need the pair to get things cooled off in a reasonable amount of time.
12-28-2020, 10:37 AM
Litchfield Park
Another consideration is today's ducted systems. I think for those with older trailers where the AC unit is blowing directly into the coach, one AC does a better job of cooling than in the newer trailers with the ducted system. If you're getting a new trailer with the ducted system I think you'll appreciate two ACs and 50A service.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
12-28-2020, 08:22 PM
2021 28' International
Knoxville
, Tennessee
Had a 2020, 25 ft. FC with one AC. Knew immediately that 2 AC's were the way to go and traded up to a 28 ft. Int..
Won't be sorry if you get two AC's. Otherwise, perhaps you will.
01-02-2021, 03:56 PM
2019 27' Tommy Bahama
Alexandria
, Virginia
At a minimum, two AC units provide redundancy. If one goes down you have one. If you only have one and one goes down, you have none.
01-03-2021, 09:42 AM
2019 28' Flying Cloud
Barrington
, Rhode Island
2 ACs
If you are in Texas in the spring, summer or early fall you will need the 2 Acs. Definitely.
