Old 05-23-2024, 01:46 PM   #1
2013 27' FB International
Mandeville , Louisiana
2nd A/C in rear bedroom through the fantastic fan spot
I have a 2014 27fb sterling 30 amp unit, and we were thinking of putting a 15,000 btu no duct a/c with heat strip over the bed through the fantastic fan vent spot. Would then run the wiring in the wall(?) and add an exterior electrical outlet to the service side of the trailer. That way, when arriving at camp site, I would plug in the normal 30 amp cord for the Airstream, and get a 110 male to male extension cord and run it from the electrical stand to the outlet to run the extra a/c.
Only part worried about is running the electrical wiring through the wall. Any thoughts on this?
Tcitruck is offline   Reply With Quote
Old 05-23-2024, 05:42 PM   #2
Sioux Falls , South Dakota
"...and get a 110 male to male extension cord and run it from the electrical stand to the outlet to run the extra a/c."
I see one very big safety concern with this: If you plug that cord into the power pedestal the prongs on the other end are live, which means that you will get a shock when you touch them. Even if you aren't the one to touch them, if they touch metal you will trip the breaker for the 20A circuit you are using.
If you really want to do this, I'd suggest you wire an extension cord from the second air conditioner to a convenient point, then use a standard extension cord of proper capacity to go to the outlet.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 05-23-2024, 08:27 PM   #3
1988 32' Excella
Robbinsville , New Jersey
I agree install an inlet not outlet.
https://www.amazon.com/BEBOBLY-Water...zcF9hdGY&psc=1
Old 05-23-2024, 09:15 PM   #4
Central , Mississippi
I’ve done that on our 34’ and it works great. I did add a separate breaker box for the new circuit inside the rear upper cabinet
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 05-24-2024, 11:01 AM   #5
redding , California
Added a bedroom AC to my 93Excella. Used a marine shore power inlet and ran wiring into night stand and up wall to added circuit breaker. From there through ceiling to AC unit.added Soft Start to second AC. Have 50 amp cable with double 30 amp connectors. I can also run both AC units with my Onan P4500.
howell57 is offline   Reply With Quote
Old 05-28-2024, 01:41 PM   #6
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
Hi all I am wanting to do this project on my 2021 FC 25. My big problem is trying to find the best option for the A/C unit. I'm thinking of a 13.5k btu to save on power. There seem to be so many problems with the dometic unit, which is what I have for the main unit that I have been looking at the Coleman. However you have to use a condensate pump and you are limited to the mach 8 unit I think.. Also many of the units I have looked at seem to run the interior fan all the time. This can cause a high humidity problem. Any sage advice out there?
Keys Dave is offline   Reply With Quote
Old 05-28-2024, 08:53 PM   #7
1988 32' Excella
I have Coleman AC I bought 8 years ago that I was able to buy a kit to change it to a wall thermostat which then allows the fan to shut off with the compressor. Note, the kit did say cooling only.
Old 05-28-2024, 09:11 PM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Male-to-male is a BAD idea. Like others have said, install in electrical inlet instead and use a normal extension cord.
One potentially serious concern in your plan is the way many camp site pedestals are wired though. On many the 20-amp outlet and the 30-amp outlet share the same hot lead coming from the campground's main panel. Depending on what the wiring is between the main panel and your pedestal, as well as the breaker in the main panel, you might find yourself blowing the main feed breaker to your pedestal by overloading it. I imagine that this is a bigger problem with older campgrounds.
It's been explained to me that the expectation is a camper will use either the 30-amp or the 20-amp outlets to plug in their RV, not both. It would still be okay to use the 20-amp outlet for some low-current things like an outside light, but running high-demand loads on both might be a problem.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 06-02-2024, 04:45 PM   #9
2018 30' Classic
Jacksonville , Florida
My AC amp load comes on at around 5 amp and rises to 11 to 14 depending upon load on the AC unit, ie temp difference
. A 20 amp breaker will "break" at 80%or 16 amps. Old breakers , especially ground fault, can go off at lower amps. Just be ready for problems with your feed on that unit.
I used to run the AC on a 20amp breaker during pack up and had similar problems.
Overstreet is offline   Reply With Quote
Bambi leaks through front fantastic fan ONLY while towing Grahambino Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 06-12-2023 09:45 PM
Replace a fantastic Fan cover with only a "Ultra Breeze Cover" by Fantastic Vent? Bob Blarney Roof Vents, Skylights & Fans 6 03-02-2022 07:32 PM
2nd A/C? Or fantastic fan on 27 with ducting? thebreezeman 2009-2015 Flying Cloud 22 09-30-2020 08:44 AM
50% off - SPOT Satellite Messenger and SPOT Trace Adventure.AS Electronics & Connectivity 0 04-23-2019 11:12 AM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
