Old 07-12-2020, 04:23 PM   #1
"Tin Willie"
1968 26' Overlander
2016 22' Sport
spring , Texas
27' Globetrotter 2nd AC Question
I am looking at buying a new 27 Globetrotter and see that one of the options is a 50 amp setup with a second AC. My question is do i need the second AC? We live in the south but do not camp much during the summer for obvious reasons. Thanks for your comments!
ibordelon is offline   Reply With Quote
Old 07-12-2020, 04:39 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
On a 27’, with ducted... yes you want and need a second AC. I don’t know what airstream even make this an option. You want this, and 50A service is a big plus.
wulfraat is offline   Reply With Quote
Old 07-12-2020, 04:40 PM   #3
Grace the Airstream
2020 27' Globetrotter
Resale value is maybe the best reason. If you can afford it get the 2nd AC and 50 amp service. With the ducted AC the two units work brilliantly.
Hard to add after the fact and you can always use 30amp and only one of the ACs.
At home we leave the AS plugged into a 30amp and at campgrounds if we can get it we do 50amp but can also do 30amp and only use one of the AC units.
Plus both units on the GT operate as heat pumps as well so it will extend the camping season wherever you are. The rear unit will even select gas or HP depending on the temp outside.
pdavey is offline   Reply With Quote
Old 07-12-2020, 04:49 PM   #4
2018 27' Globetrotter
Chandler , Arizona
We live in the metro Phoenix area and have two a/c's - one alone will not do it. Also, in addition to choice and resale, retrofitting a second a/c with associated electrical upgrade is usually not an option.
ddrg is offline   Reply With Quote
Old 07-12-2020, 04:53 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Both!
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 07-13-2020, 12:49 PM   #6
1988 32' Excella
Robbinsville , New Jersey
Not to mention, if one quits you can still use the other one.
Wazbro is online now   Reply With Quote
Old 07-13-2020, 12:53 PM   #7
2019 27' International
Western NC , North Carolina
Yes
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 07-13-2020, 01:22 PM   #8
Spaggs's Avatar
2022 28' Flying Cloud
GAINESVILLE , GA
We live in North Georgia and plan to purchase an AS with two (2). I've read a lot of threads concerning this topic and there are guys who justify their use of a single. The ones that convince me are the ones who either have a 25' or less and/or live north of the Mason-Dixon line.
I recently priced a new 27' FC and found the extra cost as being very reasonable. And since you live in the South and most likely will eventually sell in same, the additional unit will help the resale.
Spaggs is offline   Reply With Quote
Old 07-13-2020, 01:52 PM   #9
AirMiles's Avatar
Apollo Beach , Florida
Ok, I'll take the other side of this debate. I live in Tampa, FL and I'm on my second Airstream with a single A/C. My first a 25' with ducted air and my second a 27' Globetrotter with ducted air. I would recommend the three awning option and a roof full of solar panels to block the sun. I have no problem cooling my 27' Airstream in the Florida heat and humidity. Right now the temperature is 94 with a heat index of about 110 degrees. It was the same temperature this past weekend while I was camping with the grandkids in Tampa. There were five of us sleeping in the Airstream and we did not have any problems with the single A/C. I also prefer single A/C and two fantastic fans because I primarily boondock and power my Airstream with solar.
I'm aware that I'm in the minority on this one, but I have to balance the debate a little bit. I travel all over the country each summer, nearly 400 nights and 52,000 miles so far, and never had a problem with the single A/C keeping up in Arizona, Texas, Colorado, California, Georgia . . . Obviously if I had a problem with the single A/C, I wouldn't have bought a second Airstream with a single A/C.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 07-13-2020, 02:33 PM   #10
2014 27' Flying Cloud
Wenatchee , Washington
You definitely want two air conditioners. My FC 27FB came with one and I’ve regretted it every time we use the trailer (as we use it when we visit our children, two of which live in Texas).
Ultimately I hope to return to the Mother Ship to have a second a/c and 50 amp wiring installed but that’s quite a trip from the Pacific Northwest (and not cheap either).
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 07-13-2020, 03:45 PM   #11
Downhill502's Avatar
Fredericksburg , VA
While some are focused on cooling ability, ours is also on audible comfort while in each area of the trailer. It was 94* this weekend and the ability to have a nice peaceful dinner while the front/bedroom unit runs is fantastic. While cooking or sleeping, when we would like it a little cooler, let the rear 15k unit run and all is wonderful.
Downhill502 is offline   Reply With Quote
Old 07-13-2020, 04:02 PM   #12
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Get the 2 A/C's. Our 2018 26-U only had one and it did not do well at all. It's not like we wanted to buy a 2019 FC just because of disposable income!
However, the 26-U has more windows than almost any other floor plan.
RivetED is offline   Reply With Quote
Old 07-13-2020, 08:13 PM   #13
Albany , Alabama
Do you have an issue with 30 amp blowing fuses when using multiple appliances? Would 50 amp be better to eliminate the overload just from a voltage issue over a/c?
Mefree is offline   Reply With Quote
Old 07-13-2020, 09:35 PM   #14
2018 28' International
Fayetteville , Georgia
Get the 50 amp/dual AC. And the roadside awning. Lots of reasons. It is a cheap upgrade now, super expensive later. If you want to keep the temp below 80 F, you need two AC’s. If one fails, you have another. At night you can turn the living room AC on for quieter operation in the bedroom. And a 50 amp service provides extra electrical capacity - it’s actually two 50 amp breakers, for a total system capacity of 100 amps. Plenty of juice for 2 AC’s water heater, hair dryer, etc.
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 07-14-2020, 07:48 PM   #15
AirMiles's Avatar
Yes, 30A is very close if you run the A/C and microwave together, and will sometimes blow the shore power 30A fuse possibly when the water heater or battery charger is also running. This may also result when the breaker at the campsite shore power is finicky. Campground power is notoriously finicky. This past weekend, I had to use the 50A breaker at the campsite because the 30A kept popping. I chalk that one up to a faulty 30A breaker at the shore power pole. I rarely (never?) pop the 30A breaker inside the Airstream and never have a problem while I'm running on my Champion DualFuel 3500W generator downgraded to 3150W due to propane use.
Another advantage to the 30A Airstream . . . it has a 30A plug at the front of the Airstream to use with the propane quick disconnect to run the propane generator. Again, for boondocking/dry-camping, nothing beats a 30A single A/C Airstream in my opinion. I rarely camp where there is a 50A shore power plug. I rarely camp where there is even a 30A shore power plug. So again, I find the dual Fantastic Fans and the front 30A shore power connection more useful than a second A/C. Also, I could see the need for two A/Cs for non-ducted Airstreams due to the noise factor - run the one farthest away from you. With my ducted Air Airstreams, I never found the A/C noise bothersome. With my Casita, I used to get noise deftness from the loud non-ducted A/C running over my head all night.
Again, I'm just sharing the advantages to a single A/C Airstream to balance the debate. I wouldn't want a dual A/C Airstream, but understand that many others would not want a single A/C Airstream. Have you ever noticed that almost all 5th wheel campers have a single A/C? How do they keep those monsters with multiple slides cool with a single A/C? I don't get why everyone is saying you can't keep our small- well-insulated Airstreams cool with a single A/C. I never have a problem keeping mine cool.
Another example. We frequently stop at Cracker Barrel at dusk after a hot day of traveling to dry-camp in their parking lot overnight. We fire up the Champion 3400W DualFuel generator, turn on the A/C. Take the dog for a short walk around the parking lot to do his thing. Put the dog in the Airstream because its already cooled down enough for the dog. Go inside to eat dinner in the 100 degree Georgia heat. When we come back out to the Airstream in about one hour, the Airstream is completely comfortable. Most of the time, we turn the generator and A/C off and sleep comfortably all night. A couple of times (Shreveport, LA and Lake City, FL in mid-summer come to mind) we did leave the generator and A/C running until midnight before shutting it off for the night. Again, just sharing how we use our single A/C Airstream to balance the discussion, since I'm the only one commenting on the single A/C side. MooseTags from Florida usually chimes in too. He's on his third single A/C Airstream and has spent thousands of nights without an issue. I took his advice to buy a ducted single A/C Airstream with the three awning option and have never regretted following his recommendation.
Old 07-14-2020, 08:11 PM   #16
2020 30' Classic
James Island , South Carolina
Had a 25' Flying Cloud with 1 AC. Traded it in for a 30' Classic with 2 AC units. Lesson learned. Never again and will always have two AC Units.
Lou
KC5ME is offline   Reply With Quote
Old 07-14-2020, 11:04 PM   #17
Albany , Alabama
Thank you.
Old 07-15-2020, 03:36 AM   #18
Sag Harbor , New York
Why not have another tool in the tool bag, in case you need it at some point?
The extra cost is just good insurance for resale value.
KISS
Newbie intro and 50 amp 2nd AC question cptdzl Buyer Guidelines 33 04-27-2019 06:06 AM
2nd a/c failed for 2nd time Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 15 01-02-2019 05:23 PM
2nd Air Conditioner Question MWBishop Furnaces, Heaters, Fireplaces & Air Conditioning 29 02-16-2017 08:33 PM
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
