Old 02-15-2025, 12:50 PM   #1
Chicago , Illinois
23 Globetrotter Heat Zone Issue
We have 2 zones on our 23 Globetrotter for our AC and gas heat. Zone 1 is the bedroom and 2 is the living area. When using the AC, we can select a zone and temp and the AC will work for that zone. With the gas heat, if we select Zone 2 the heat comes out of the 2 vents in the living area. If we select Zone 1, the heat comes out of the 2 vents in the living area and the one vent in the bedroom. Zone 1 will not control just the bedroom vent, like the AC. Is this normal operation? If not, anybody know what’s wrong? Thanks!
SusanEL is offline   Reply With Quote
Old 02-15-2025, 04:23 PM   #2
2018 27' Globetrotter
Mooresville , North Carolina
Not sure if this will work but, make sure the fan is set for “auto” for zone 1 and zone 2 and see if that makes a difference.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 02-16-2025, 10:10 AM   #3
2023 27' Globetrotter
Williamsburg , Virginia
Hmm. General rule of thumb for a 2 zone system is, zone 2 is the ONLY zone that will power and control (thermostat) the gas heat. Your A/Cs will work independently as will the Heat Pump when engaged, but if you want to operate your propane furnace, only Zone 2 will do that. When you engage gas heat, you should get flow from the floor vents in the front and rear of your rig. This was true in our '19 FC 27, and is true in our '23 GT 27.
AgBullet is offline   Reply With Quote
Old 02-16-2025, 10:52 AM   #4
The above is correct and this is also the way our 27’ Globetrotter works. I missed the fact that you were using the propane for heat.
On the heat pump side I believe you can have heating issues if the fan is not in the auto mode for both zones.
"Roadrunner"
Old 02-17-2025, 06:08 AM   #5
Chicago , Illinois
Thanks. What you describe makes infinitely more sense but it didn’t seem to be the way the propane heat is working. I’ll switch to Zone 2 from now on and deal with the apparent anomaly when we get back to our dealer in a couple of weeks. It’s pretty cold on the road in southern Texas right now.
Old 02-17-2025, 01:06 PM   #6
2021 23' Flying Cloud
2024 25' Globetrotter
Louisville , 40222
Another question on Ac/heat
We have a 2024 Globetrotter 25fbt with the two Coleman AC units. We have found that the thermostat for these units is not very intuitive and has been a sense of frustration with this new trailer. Our first trip out we had to call our dealer to help us try to determine why the unit was not functioning correctly. There was some confusion on the zones as perhaps it was wired wrong. I recently looked at a 2025 globetrotter and it appears they are now using the GE units. I actually have been considering changing the thermostat to the micro air as it seems that most folks prefer it versus the Coleman. I have an appointment coming up at JC in March and have on my list for them to check the Coleman unit first to make sure it is wired correctly and then perhaps I will then change it if it’s determined that it’s correct just hard to navigate! Any thoughts on the Micro Air?
Deholden is offline   Reply With Quote
Old 02-17-2025, 06:42 PM   #7
Not a fan of the Coleman thermostat, but after two years, I will say the A/C and heat pump do their job well. I have considered the MicroAir thermostat myself, and if you do install one, I'd be very interested to know if it's an improvement.
Zone 2 AC Works Great, But Not Zone 1 Alumaholic Furnaces, Heaters, Fireplaces & Air Conditioning 21 02-14-2021 06:12 PM
Which one is zone 1 and zone 2? Doc Foster Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-23-2017 10:52 PM
Can I run the furnace in one zone and the heat pump in the other zone? Philip Jones Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-15-2017 03:24 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
