Old 06-22-2017, 06:39 AM   #121
1989 32' Excella
Sharon Springs , New York
If you like the stove and it's quality, maybe you could have a LPG technician check it
for safety and performance, then decide whether to replace/retain. Did that on my 1989 Excella and the unit checked out as almost brand new, so I kept it in place...
MAJORJDB is offline   Reply With Quote
Old 06-23-2017, 12:29 PM   #122
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We installed the Dometic CU434 stove in both the 2014 Classic and the 2015 23D International Serenity. We also installed magnetic stainless steel side splash panels.
We retrofitted Vitrifrigo 12Vdc DanFoss freon compressor refrigerators in both trailers as well. As they are marine units, they both were slightly narrower than the ones they replaced and the one for Classic was enough shorter we made a custom storage space above it.
Name:	16-Finished stove install copy-Quick Preset_1080x1440.jpg
ID:	288035   Click image for larger version
Name:	18-Spice rack behind open burner lid copy-Quick Preset_1080x1440.jpg
Name:	28-Finished storage cabinet and new refrigerator copy-Quick Preset_1080x1440.jpg
ID:	288037   Click image for larger version
Name:	IMG_3267 copy-Quick Preset_1080x1440.jpg
Name:	IMG_3276 copy-Quick Preset_1080x1440.jpg
Old 06-23-2017, 02:46 PM   #123
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Originally Posted by Caroyl View Post
Love the quartz counters with the CU-434 [emoji1303] Any idea what the counters weigh?
Good question. It's 2cm or about .75", around 8 feet long, minus the cutouts for the sink and oven. My guess is 110-120 pounds. We also have a dinette table in the same material, 46" by 32" and maybe 75 lbs. Far heavier than I would like, but hopefully I've balanced the layout well enough that it won't cause problems.
We'll use a Hensley Cub, so that should help also.
bredlo is offline   Reply With Quote
Old 08-13-2017, 11:00 PM   #124
4riveteers's Avatar
2016 27' Flying Cloud
Manteca , California
Before...
After...
Installed my wife's new SMEV range oven. She's happy, so I'm happy![emoji7]
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
4riveteers is offline   Reply With Quote
Old 08-15-2017, 09:16 AM   #125
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Why do all replacement ranges look so cheap?
How did you fill the gap without installing a new counter top surface? My understanding is that the new unit is slightly narrower than the old one (but I could be wrong). did this turn out to be a drop in replacement with no modifications to the cabinetry necessary?
Could you provide a photo top-down of the new stove?
I bought a new trailer and I have the same crummy stove from airstream now. I'm looking to also replace like I did on my other trailer.
Looks great!
wulfraat is offline   Reply With Quote
Old 08-15-2017, 12:27 PM   #126
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Nice. How's it work?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 08-15-2017, 01:33 PM   #127
4riveteers's Avatar
Looks great!
Thank you kindly for the shout out! We have a 2016 27' FC FB that had the factory Atwood s/s bi-fold cover. Yes, the SMEV range requires a slightly smaller opening width and height wise, and deeper depth wise. Sadly no, it was not a drop in replacement without mods. SMEV also has an oven light and electronic ignition so I also had to wire 12 volt to my circuit breaker.
After removing the factory range and dry fitting the SMEV, I discovered the new range fits right in width wise, flush with the counter (it's designed to rest on top of the counter like the factory range). So to make the new range appear flush with my existing counter, I used furring strips underneath to keep range at the desired height. There are three screws on each side that I screwed through the furring strips into the cabinetry.
Here's some top view photos.
ID:	292297Click image for larger version
ID:	292298Click image for larger version
ID:	292299Click image for larger version
You can find my original posting for this project in airforums under "Frank&Mike 2016 27' Flying Cloud We Made Some Changes".
I have a detailed installation guide with photos that a member requested.
Glad to help out a fellow Airstreamer. It was a labor of love but always worth it. Good luck!
Old 08-15-2017, 02:45 PM   #128
4riveteers's Avatar
Much thanks! SMEV range oven has a 12 volt electronic ignition and an oven light. Lighting the burners is similar to a residential gas range. To light burners, push in and turn the knob to "light" and it clicks until it lights. To use oven, push in and turn oven knob to "light" and push a separate button to ignite. The oven has a setting up 450*[emoji91]The cook top glass lid raises up and creates a nice backsplash. SMEV claims the burners use 33% less gas while still providing high temperature cooking because of the efficiency of the JetFlow burners. Sadly we've only cooked one time using only one burner. We did notice the flame was more "jet-like" and cooked nicely. My wife is the chef so she would notice any deficiencies.[emoji848]So far so good!
Happy travels!
Old 08-16-2017, 06:16 AM   #129
wulfraat's Avatar
Attachment 292297Attachment 292298Attachment 292299Attachment 292300
Thanks for the info - I was pretty sure it had different dimensions. You did a nice job fitting it in without replacing the counter top - something I'm considering for my 30'.
Old 02-07-2018, 09:59 AM   #130
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Here’s our SMEV installed during our total renovation of Gracie, a 1964 Overlander.
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Old 02-07-2018, 10:23 AM   #131
4riveteers's Avatar
Looks great! You will be happy with it. Can you give any details about that heater in the lower left hand side of the pic? Thoughts on performance? Brand, power source? etc.
Old 02-08-2018, 09:05 PM   #132
Caroyl's Avatar
1964 26' Overlander
Absolutely [emoji2] the heater is the Platinum Cat and is a VENTED catalytic heater which uses less propane and a tiny bit of battery (12v) power. For more info see http://ventedcatheater.com/6.html
It works great so far. We had tent trailers before our Airstream and never got more than one (partial) night of heat before the battery died and the furnace shut down [emoji15][emoji22][emoji35] so I “just said no” to replacing the furnace. Used the money saved to buy this heater instead. It is vented to the exterior of the trailer so there is no need to leave windows open.
Arnie builds them to order, so you can choose a color too. Click image for larger version
ID:	303804Click image for larger version
Caroyl & Tim
WBCCI # 31088
Old 06-02-2018, 09:58 AM   #133
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
Furrion Range
I think this range from Furrion looks nice:
https://www.furrion.com/store/applia...el-p-1103.html
Now, I just need a few of you to purchase it, install it, and let me know how it turns out.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Old 07-19-2018, 07:43 AM   #134
2016 22' Sport
1991 36' Land Yacht
Leiston , Suffolk
I live in the UK and I was also looking to buy a Dometic Cooker for my caravan. Comming across this thread I hoped to get the same great deal you had but it looks like the link from the shop no longer work. A quick search on google revealed another chandlery not too far from where I live selling it also but the price is higher than the one you point out. Even so, I could not find a better price elsewhere. Am I being ripped off?
danj79 is offline   Reply With Quote
Old 09-07-2018, 06:39 PM   #135
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Anyone interested in helping me solve my Dometic CU-434 mystery, head over to this thread (linked below) and take a picture of your oven burner for me
http://www.airforums.com/forums/f426...ml#post2153067
trekerboy is offline   Reply With Quote
Old 09-10-2018, 08:05 PM   #136
trekerboy's Avatar
Originally Posted by trekerboy View Post
An update and question on my Dometic CU-434...
I noticed today that the rear left burner will no longer light. There is a visible spark, and I can smell propane when I press in the knob, but no flames. I've tried to light it with the spark ignitor for up to five seconds with the gas knob pushed in, but it still wouldn't light. I am reluctant to let gas flow through the burner any longer than that for fear gas build up.
The other turn burners work fine.
Do I need a new burner? Or do I just need to adjust the ignitor for a different spark?
Any advice is appreciated.
Fixed! The burner was just dirty... I took the cap off the burner, cleaned the area where the flames come out, and viola, works like a charm!
Old 09-17-2018, 10:36 AM   #137
2007 28' International CCD
San Marcos , California
You might consider the Dometic Stainless Steel Range. Model number CU434 on the Dometic website under RV Cooking Range. Three burners with a LP oven, glass top for extra counter space when not in use, window in the oven door, and there is a light in the oven. I think it is a very handsome range with nice details to the design. My present range works perfectly well, however after seeing this one, I want to replace mine! (Wife will kill me dead!) If anyone has any experience swapping out ranges, I would love to hear from you! Mike
BlueStreakSD is offline   Reply With Quote
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
1954 Safari serial number ranges yukionna 1954 - 1959 Safari 0 10-08-2005 05:54 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
