Old 04-29-2024, 09:15 PM   #1
2007 25' International CCD FB
Glen Allen , Virginia
Upgrade Stove/oven to Stove MW
I want to upgrade our stove/oven to a Stove/MW and would appreciate
any recommendations or lessons leaned.
We have 2007 25FB so our stove/oven unit is 21.5 " wide. I have not found
any of the combo stove/MW in 21.5" W. Is the solution an cook top and separate MW unit with an enclosure?
If you have experience with this or have done the upgrade, I would love
to hear from you and please include the model numbers of the units you used.
Thank you all for any assistance.
Bill
Richmond Va
dabhunter is offline   Reply With Quote
Old 04-29-2024, 09:40 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you're handy it should be pretty simple to install a shelf to mount a surface mount (drop in) stove and then the micro/convection under it using a mounting kit.
All depends on how much space is left after you remove the existing stove/oven combo.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 04-30-2024, 05:36 AM   #3
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
We’re in the exact opposite position, planning to convert our propane stove/electric convection microwave to a straight propane stove/oven.
Ours is a propane cooktop with the convection microwave boxed into cabinetry immediately under the cooktop. At first glance it appears like a single combined appliance, but they are separate.
This is on a 2017 19’ Flying Cloud. Not sure if the size is the same as used in the larger trailers, but I can get some measurements and photos if that’s any help.
We’re up in the NoVa/DC area. Not sure what your timeline is, but we’ll be looking to sell off our current barely-used appliances when we make the switch (probably sometime this year.)
2017 Bambi 19 Flying Cloud
BikeCamper is online now   Reply With Quote
Old 04-30-2024, 06:18 AM   #4
Oak Park , Illinois
I just did this, of I should say the factory did it for me.
I had the Furion cooktop and convection microwave. I kept the convection microwave, but had the factory remove the cooktop and and install a full out Furion oven. We boondock a lot so although when we do have shore power the convection microwave is nice, I don't typically lug a generator around with me, so the conventional stove/oven combo was a must for us.
I have the Furion cooktop if anyone is interested, PM me.
sfranklin is offline   Reply With Quote
Old 04-30-2024, 07:30 AM   #5
BikeCamper's Avatar
That is pretty much our use scenario too.
Can I ask, what did the factory charge for the conversion/installation?
Old 05-01-2024, 10:11 PM   #6
This is very interesting
Our stove/oven is in nice shape, I doubt the oven has ever been used.
Please send me the Width & H of your stovetop/MW.
Is your stovetop/ MW is a single unit or two separate units.
My stovetop/oven is a single unit.
I live on the northside of Richmond.
Old 05-02-2024, 05:02 AM   #7
BikeCamper's Avatar
Our propane stovetop and electric convection microwave are two separate units. I took some photos, but it is hard to capture the measurements. The stove top is 21” wide, the microwave is narrower but it has a “surround” trim that fills any gaps.
ID:	443165   Click image for larger version
ID:	443167   Click image for larger version
Old 05-02-2024, 05:08 AM   #8
BikeCamper's Avatar
Here are more photos of the convection microwave:
ID:	443169   Click image for larger version
Old 05-02-2024, 06:36 AM   #9
Oak Park , Illinois
I would have to double check, but I believe it was about $2300, which included the stove, labor and possibly the cabinetry that facilitated the oven (I believe they have two different cabinet part numbers, one for the oven, one for the cook top). Not inexpensive and half of me thought the dimensions are similar, what if I just get the oven, remove the cook top and sawzall the opening? All the electrical and LP gas tubing is already there. I just figured for the extra $1700, having the proper cabinet without collateral damage from the sawzall would be worth it and it was, you cannot tell that the oven was not an at the time of construction factory install.
Since we boondock equal to or more than we connect to hookups, the gas oven has been very handy. I also feel that the convection microwave is far better than the standard microwave the comes if you do get the oven installed at the time of construction. Having this setup, at least to me, gives me the option and the best of both worlds. Sadly, if my unit does get totaled, the deposit I have down on a new unit, also has the cook top.
I know, good first world problems to have, right?
Old 05-02-2024, 06:43 AM   #10
BikeCamper's Avatar
Ouch! That is steeper $$$ than I expected. It looks like such an easy swap. I will likely end up doing it myself, then.
So are you saying that there is a stand-alone propane oven (without cooktop) that might fit in the space currently occupied by the convection microwave? Or did I misunderstand you?
And good luck with the on-going insurance claim.
Old 05-02-2024, 08:52 AM   #11
aftermath's Avatar
Spokane , Washington
Bill, I have a 2006 25FB and replaced my stove with one I found on RecPro for about $600. It is a standard stove oven which we prefer. I did the work myself and did run into a few issues you should be aware of.
If you are going to change to a microwave, you probably won't find an power behind/under your current stove. You will need to plan for that. Also mine was not an exact fit. The height of it was smaller so I had to install a spacer board at the bottom. The width was perfect but the depth of the new unit was smaller than the opening, by about a half an inch. The new stove, an imitation of the Furion, has flat aluminum trim on the sides but none at the back. I found matching flat aluminum trim on line and ordered one the same width as the sides and it looks original. Very happy with our new oven. I got really tired of lighting the oven pilot light every time we used it.
Also, the gas line on my old stove came in on the left whereas the new unit is on the right. I had to cut and re flare the pipe to move the input line where it needed to be. There is flexible gas line out there but I chose to just shorten the line. Best wishes.
aftermath is offline   Reply With Quote
Old 05-02-2024, 09:32 AM   #12
Oak Park , Illinois
No, I got the standard oven/cooktop.
https://www.dyersonline.com/furrion-...lVX3Ei0VA0jZkE
I do really like it, for the 4x I've been able to use it since picking up the rig from JC last month. Besides it being relatively accurate for an RV oven, I really like there is an oven light inside!
Thanks, I'm hoping for a final, final verdict today or tomorrow.
Old 05-05-2024, 09:35 AM   #13
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Not sure i would consider getting rid of your oven an “upgrade”.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 05-05-2024, 09:47 AM   #14
BikeCamper's Avatar
That seems to be a matter of personal preference. In our recent shopping experience, we found many trailers where owners proudly advertised that they had upgraded to the convection microwave option. To the point where propane ovens were quite scarce in the model years we were targeting.
We eventually “settled” for a trailer with the convection microwave, with the intent to swap it for a propane stove. But it seems the majority of owners/purchasers would prefer the microwave.
Old 05-05-2024, 12:13 PM   #15
1 Rivet Short
1989 25' Excella
yep-for sure.
Depends on how you camp.
90% of our camping is off grid. Anything using a lot of electricity is useless for us.
Not only that but fresh baked pies, pizza, cc cookies fresh out of the oven on a fall day-yum.
Old 05-05-2024, 03:12 PM   #16
BikeCamper's Avatar
yep-for sure.
Definitely. Same here.
Old 05-05-2024, 08:45 PM   #17
1994 25' Excella
yep-for sure.
I would agree with this as well. We often spend multiple dry camping nights in rest stops, Harvest Host sites, parking lots, ect. on the way to our final destination. Without the gas stove/oven we'd have to run the generator in all these locations to cook. Having the gas stove/oven combo makes it quite simple to prepare meals as we make our way across the country.
When we get to our full hook up campsite, we also have a microwave and plug-in induction cooktop for use when needed. They take up relatively little space and don't weigh much so we take them on every trip for convenience if we're using sites with hook ups.
Richard
11018
Old 05-06-2024, 06:30 PM   #18
Thank you all for your input on this stove/oven project. I
appreciate your experience and insight into your use cases
for the Gas oven vs MW.
I especially appreciate the warning that there may not be an
AC outlet for the MW.
Can someone give the brand & model #'s for the MW and the surround trim kit?
Thank you all again for your responses
Old 05-08-2024, 04:17 PM   #19
BikeCamper's Avatar
Here are some photos showing make/model of our convection microwave. I could not see any model or part# for the surround.
ID:	443324   Click image for larger version
Old 05-08-2024, 05:31 PM   #20
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Furion makes a propane cooktop that may drop in. Then you will have a cavity below that you can finish as you like and put the microwave of your choice in.
Thats what we did. My 2018 FC25 had an outlet behind even though the trailer didn’t have a microwave as built.
daleyocum is offline   Reply With Quote
SOLD: Vintage PINK STOVE 1960s Magic Chef 4 Burner Stove Oven - Illinois beanPod Airstream Classifieds 0 11-13-2022 11:02 AM
Stove replacement/update with Airstream Classic stove/oven? JakoVdL Stoves, Ovens & Microwaves 0 10-18-2021 03:37 PM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 2 08-26-2020 08:21 AM
Switching propane oven out with the mw/convenction oven Deb Trimble Airstream Lifestyle 17 09-27-2012 09:26 AM
Oven VS no oven trogers713 Stoves, Ovens & Microwaves 36 10-30-2003 01:53 PM
