Old 11-19-2020, 04:54 PM   #1
Whtesocks
2014 31' Classic
Crane , Missouri
Stove not lighting
So when we turn on the burner and hit the electrical switch it doesn't light. I can hear it firing but it doesn't light the burner.
Is there something that needs to be cleaned?
dmnichols is offline   Reply With Quote
Old 11-19-2020, 04:58 PM   #2
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Am I correct in assuming that the stove uses propaneDo you know if your refrigerator and or furnace will turn on using propane
urnmor is offline   Reply With Quote
Old 11-19-2020, 05:00 PM   #3
2019 27' International
Western NC , North Carolina
Stove not lighting
Do you hear gas? And are you pushing in on the knob to bypass thermocouple? Have you checked to make sure tank is open and/or has propane. Stoves are pretty simple. Also have you tried switching tanks?
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is online now   Reply With Quote
Old 11-20-2020, 01:12 PM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I always have to use a lighter stick. The ones on the stove just don't do the job.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 11-20-2020, 03:53 PM   #5
Pat
If you do this and don’t see the flame flickering when you hold near the burner, no gas is flowing. Odds are either out of gas or bad regulator
If the flame flickers but doesn’t light it’s air in the system just wait till it lights.
Old 11-21-2020, 08:56 AM   #6
Ready-to-Travel
pmclemore's Avatar
Mine lights just fine. Just won't start with the stove igniters.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 11-21-2020, 09:21 AM   #7
2019 16' Sport
Nelson , British Columbia
Pat
Hi Pat,
Have you tried wiping the igniter with paper towel? This helped me.
You should see the igniter spark when you press the button. You might have to press it repeatedly and quickly to get the gas to burn.
Scott
sdwilsonsct is offline   Reply With Quote
Old 11-21-2020, 09:48 AM   #8
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Have you confirmed that you have gas to the burner? Try lighting the burner with a match. If you have no gas to the burner, you could have several problems. 1. Tanks not turned on. 2. Empty tank. 3. Faulty regulator. 4. Valve below stove on the underside of the trailer turned off. 5. Faulty stovetop valve. Could be any one of the above, or a combination. Can you smell gas? If all else fails take to a RV dealer, or propane service centre, for diagnosis.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 07-12-2021, 10:00 PM   #9
2019 25' International
Colorado Springs , Colorado
Pat
Did you ever get your stove to light with the igniter? I’m out on a trip and mine just stopped lighting. It worked on Sunday before we left but now won’t light. Just curious what you might have done to fix your problem (if anything). Thanks.
Xbc3 is offline   Reply With Quote
Old 07-13-2021, 06:01 AM   #10
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
I always found the igniter switch is randomly reliable. It works today and not tomorrow. Just use the long lighters found everywhere, and these always work if you got propane gas. Of course, if you have no gas flowing to your cooktop, time for refills.
Martee is offline   Reply With Quote
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 15 05-19-2020 02:10 PM
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
lighting old stove / range quiknot Stoves, Ovens & Microwaves 7 09-29-2007 09:57 PM
'59 Traveler stove lighting problem turbocharger Stoves, Ovens & Microwaves 0 07-20-2005 04:48 PM
