Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-24-2021, 02:34 PM   #1
1992 29' Excella
PLANO , TX
smoke and smell plastic burning when using microwave
First time tried to use microwave in my 1992 Excella AS. A lot smoke came out and it smelt plastic burning. what could be the issue? Thanks in advance.
Xin Li is offline   Reply With Quote
Old 01-24-2021, 03:00 PM   #2
2018 30' Flying Cloud
Springfield , Ohio
It would be prudent to pull the microwave out and inspect it for problems. If nothing is apparent, plug it in and test it outside the cabinet where you can see where smoke or the burning smell might be coming from. I would replace it if there were any sign of problems. A microwave is not an expensive item.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 01-24-2021, 07:25 PM   #3
2017 25' International
West Lake Hills , Texas
Might be just burn in. Fairly simple to pull it out and take a look. I took it out of the AS, turned on the oven to 350 degrees, and let it run a while. It smelled a bit. Did the same a day later...less smell. Now, no smell. YMMV.
If the unit is defective, they are relatively inexpensive to replace.
Fungus is offline   Reply With Quote
Electrical burning, heavy smoke w/ 3yr old grandson sleeping in AI Alex AVI Sprinter and B-van Forum 232 06-13-2019 08:05 PM
Ahhhh.... the smell of Campfire Smoke Ray Eklund On The Road... 29 07-29-2016 03:12 PM
Smoke smell and hot breakers CMSmith Batteries, Univolts, Converters & Inverters 2 08-07-2015 08:16 AM
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 06:28 PM
