Originally Posted by flyfishrra
So if it is a switch that controls the microwave and ac then where does the microwave plug into so that the switch will work? Mine does not have a microwave in it currently. We live with out one just fine but i would like the switch to work.
The microwave is in a cabinet just behind the stove and spice rack in this photo. The bottom of the cabinet is just about even with the top of the stove, at the same height as the spice rack — across the hall from the mirror.
The outlet itself is in the exterior wall behind the bulkhead you can see, behind the spice rack.
I assume that the original was built-in there, but the one that was there was not the original. I've bought a Sharp Grill2 and plan to built it in, but haven't yet. I took the Goldstar that was there to work. It worked great, but the Sharp has the convection and grill features. Works great.
Vaughan, does that switch work even though it is only rated for 15-20 amps? My exterior plug is 30amp.
I can pick one up but I might need some advice on wiring since the wires are basically wire nutted together right now. I figured they did something important just wasnt sure what!
Matt
It works fine. If you check your breaker box, you will see that your AC breaker is only 20 amps. You're only switching that circuit, not the entire trailer's 30 amps.
The wire comes from the breaker box to the switch's "in" connections. The switch has two "out" connections. One goes up to the AC and the other goes to the outlet at the back of the microwave cabinet. Simple.
I'm assuming that the AC is working now, so the connections that are wire-nutted together have to be the ones from the breaker box and the AC. Now you just need to locate the wires from the microwave outlet and you're ready to install the switch.
