Old 07-17-2020, 07:17 PM   #1
Livingston , Texas
Range exhaust fan exterior fan flap tabs
The tabs that secure the exterior exhaust fan flap for travel on my 2019 FC are woefully inadequate. They continually fall off when opening and closing them. Does anyone have a similar problem and if so, what is your solution?
2019 Flying Cloud 27FB
2011 F350, SB SCREW SD
“Be thankful we’re not getting all the government we’re paying for” Will Rogers
dzwiss is offline   Reply With Quote
Old 07-17-2020, 07:36 PM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
mine are VERY stiff . they never budge at all
ask a dealer to bend the little tabs so that they are less likely to move
waninae39 is offline   Reply With Quote
Old 07-17-2020, 07:43 PM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Ours failed on our last rig.
I used 2 pieces industrial sticky back velcro to hold the flap shut during travel on the 2 bottom corner edges.
Worked well and I had the gray color velcro so almost invisible.
Added an extra piece on the frame of the flap to "stick" the piece onto when the vent is open so that the top piece had a place to stick onto the frame so it didn't get lost.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 09-13-2020, 06:23 PM   #4
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
I have a roll of Duct Tape for keeping the vent flap open when using and closed when moving. The tabs fell out while traveling in 2007.
Somewhere in Colorado. Duct Tape sealed the vent cover at West Wendover, Nevada when parked at a Casino Parking lot in 2008. Bought a replacement in Reno and it lasted until we sold the 2006 for Eight Years, put a Camco cover on and saved myself lots of Duct Tape.
So Duct Tape everything temporarily... or permanent.
Sharp razor. Small strip of Duct Tape holds it closed, and open. If the repair looks funky, I learned everything how to work on our Airstream from reading:
What Me... Worry? Alfred E. Neuman. He would have done the same.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-13-2020, 09:13 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Screen clips in the screen department at Ace hardware. Perfect replacement in aluminum.
sheriff1 is offline   Reply With Quote
Old 09-13-2020, 09:28 PM   #6
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I found a plastic wire hold-down clip in my junk drawer that was exactly the right size. I installed it will plastic screw, washer and nut from the hardware store (very tricky to get the screw on the back side).
I have also used a piece of tape when traveling. I use 3M stucco tape, not duct tape. It comes off cleanly and can be re-used several times. And DON'T use Nashua stucco tape--leave mucho gum behind.
SSquared is offline   Reply With Quote
Old 09-14-2020, 02:28 PM   #7
"Cloudsplitter"
I use a custom wooden model that has the nice feature of holding it open for more flow and closed in the rain.
ID:	378635   Click image for larger version
Old 09-14-2020, 04:04 PM   #8
2017 20' Flying Cloud
Williamson County , Texas
Yep, except we use two shiny stainless steel clothespins LOL. You discovered as did we that the flow with the stainless vent is reduced pretty significantly vs the plastic vent since the flap is too heavy to open all the way on its own.
GMC Canyon V6 Mallet Supercharger
Chevrolet K2500WT 454
SYC2Vette is offline   Reply With Quote
Old 09-14-2020, 05:31 PM   #9
Senior Member
sheriff1's Avatar
Sparks , Nevada
The correct fix.
Kitchen exhaust hood flap on exterior fell off sowhead Windows, Doors, Locks & Vents 2 06-03-2020 10:34 PM
Range exhaust fan Bougeois 2016 - Current Classic (all lengths) 3 06-24-2018 04:28 PM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Range hood exhaust fan KyMoonshine Roof Vents, Skylights & Fans 3 02-20-2011 06:28 AM
Looking for a range exhaust door flyinbrian All Argosy Trailers 0 09-23-2009 01:26 PM
