[Did you get one installed? Do you like it if you did?
QUOTE=truckasaurus;2478213]I was planning on installing a Summit 2 burner propane cooktop but came across a combo unit from True Induction which I like the look of. There's a few variants but my favorite has a large induction area and also 2 propane burners (with thermocouples).
https://www.trueinduction.com/Single...ouble-Gas.aspx
I like that I could use induction to cut down on waste heat and humidity in the trailer or use propane if I'm not on shore power/ conserving the batteries.
Lowes has them so I'm a bit surprised I haven't seen the, mentioned much.
Just wondering if anyone had tried one?[/QUOTE]
