Old 05-06-2020, 11:44 AM   #21
2020 23' Globetrotter
2019 23' Flying Cloud
Sugar Land , Texas
Tommyglen, Thanks for the information, but unfortunately the rotation cannot be stopped in my convection microwave (Contoure RV-200S-Con). If it could, then my toaster oven pans which I LOVE, could be used. I guess I’m going to have to adapt to using only 8” round and square pans. Tell your wife I said thank you for the input. Seanette
smeserole is offline   Reply With Quote
Old 05-06-2020, 11:48 AM   #22
Sugar Land , Texas
Alan, yep! That’s my problem. My Toaster oven size pans fits but not if the turntable rotates. And unfortunately, there is no way to turn the turntable off, so I guess I can only use 8” round or square. I was hoping there would be a way to turn off the rotation, but it doesn’t appear that my model (COuntoure RV-200S-CON) allows me to do that. THanks, Seanette
Old 05-06-2020, 11:59 AM   #23
Sugar Land , Texas
Stast01,
I agree! However, the oven’s manual says NOT to use the oven without the turntable in place and NOT to restrict the turntable. But....if I’m using the rack, there should be no reason why I need the turntable. Right? I’m going to call COuntoure and ask them WHY the turntable glass has to be used. Thanks, for this information.
Old 05-06-2020, 01:24 PM   #24
Sag Harbor , New York
IMO/FWIW
I would guess, Seanette, that the mfg. has certain design parameters about how hot the cooking container can get. Keeping it spinning on the turntable will tend to equalize any small internal temperature disparities.
Using a square pan, without the turn table turning, could result in random high internal temperatures at unpredictable spots, which might result in the container cracking due to internal stresses in the material.
Pyrex square glass baking dishes containers come to mind, as possibly subject to this IMO.
In any event, just as any manufacturer does, this one likely wants to minimize exposure for personal injury and property damage.
Peter
FWIW
Old 05-06-2020, 01:33 PM   #25
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by smeserole View Post
Foiled Again,
Thanks for the info. Not a fan of Dutch Oven cooking...did lots of it when tent camping with Boy Scouts and my kids. We love having an oven inside. But, I will adapt to 8” square and round pans. However, If I really need to cook something a bit larger, I like your idea of a toaster over...in a pinch. Thanks, Seanette
Yep, I finally broke down and bought a toaster oven. And I am learning to love it. Boy oh boy, there is always a new gadget or tool to try. I may find that the setup and heat up time for DO cooking is offset by the speed of a portable oven. Big quantities though, the DO's rule!
Old 05-06-2020, 01:43 PM   #26
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
We just purchased the 2020 GT 23Twin and it came with the convection microwave, along with a round rack and round baking pan. My question concerns baking in the convection oven. Can I NOT use a small rectangle baking pan in the convection oven or do I always have to use a round pan? I like to bake and would like to use my small muffin pans or small rectangular pan. I’ve read the manual and it states to use the included rack and a pan without protruding edges, like the included round pan. The problem is that the turntable rotates, and there doesn’t seem to be a way to turn it off, so using anything other than a round pan will interfere with the rotation.
I’ve looked online and other convection microwave ovens have racks built in (just like a regular oven) so that pans slide onto the rack, but in the Airstreams, it is a rack that is placed on the turntable....which doesn’t seem to have an on/off switch.
Any suggestions? Do any of you bake with something other than the included round pan? If so, what do you use and does it cook/bake correctly?
Seanette Meserole
You can use any kind of pan that will fit in the oven cavity!
Larry C is offline   Reply With Quote
Old 05-06-2020, 02:47 PM   #27
2019 25' Flying Cloud
Newmanstown , Pennsylvania
So just wondering. Could you remove the glass and wheeled circle and insert a pan upside down so that the rotating drive wouldn't be touching anything and then put the pan you want to bake in on top of the upside down pan. Would that work?
Jonmad is offline   Reply With Quote
Old 05-07-2020, 05:10 AM   #28
Thumbs down
That would seriously compromise the air circulation around the baking pan IMO, thus spoiling the even convection baking of, say, a cake or bread, which relies on very even temps all-around. Convection ovens are great because they surround the bread/cake with a very consistent air mass.
Peter
Old 05-07-2020, 05:21 AM   #29
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yeah, but I do not see why you could not remove the rotating plate, put the wire rack in and put the pan on the wire rack. I just tried it in mine and the wire rack straddles the rotation element so the rack and whatever is on it do not move.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-07-2020, 05:46 AM   #30
Larry
This sounds like it would be almost like a home convection oven. It would be nice if the rack didn't have the nubs sticking up on both sides. Then it would be just like home convection cooking. It would support the whole pan instead of sitting on the nubs with only three support points.
Old 05-08-2020, 09:24 AM   #31
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Our problem is a little different. We purchased a 2012 FC last year. It has the original Mic/Conv oven but unfortunately the previous owner didn't leave the rack behind. We have looked hard and can't seem to find the correct replacement. We are able to bake without it but no roasting. Any thoughts on where we can find a replacement rack?
Chuck & Janet
ChuckZ is offline   Reply With Quote
Old 05-08-2020, 09:57 AM   #32
What is the brand and model number, ChuckZ? Does the mfg. not list any parts available for it?
In the briefcase which came with the trailer, which contains your owner's manual, there should also be a mfg. pamphlet for the appliance, which should have a parts list IMO.
Peter
Old 05-13-2020, 09:42 AM   #33
Mollysdad's Avatar
That's what I did. I took out one rack also. I never made friends with a convection/microwave. I burned everything, even vegetables.
The other issue was what to do with the parts you removed. They take up valuable counter space.
When I got the Airstream, I didn't want the microwave at knee level and so I opted for the oven (which I use to store bread) and the small microwave in the pull out drawer.
Old 05-13-2020, 02:23 PM   #34
2018 30' Classic
Williamsburg , VA
Can I use a metal convection cooking pan in this microwave if I only use the convection mode? Mine is the Cuisinart in the classic.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 05-13-2020, 04:12 PM   #35
What does the instruction book say?
There should be one in the briefcase that contains your AS owner's manual.
Peter
Old 05-13-2020, 04:36 PM   #36
The convection part needs the raised rack to get the hot air circulating.on all sides of the item being cooked. No hot air under the pan equals a raw bottom.
Get the model number off the plate on the oven. Then go to the manufacturer's website or the dealer, or.Amazon for replacement.
Old 05-13-2020, 06:00 PM   #37
2018 30' Classic
Williamsburg , VA
Thank you. The pan I purchased is made for air frying with open holes all around so it should work fine. I was just worried about the metal in the microwave but I guess I'm good.
2018 Classic 30
2012 F250 6.7l
Old 05-14-2020, 07:23 AM   #38
ChuckZ's Avatar
1966 26' Overlander
Peter
Sorry for the delayed response Peter. All of that is in the trailer at the storage facility. I will try to get by there in the next few days.
Chuck
Old 05-14-2020, 08:01 AM   #39
Thanks.
FYI this other thread is cookin' with info too:
https://www.airforums.com/forums/f48...ml#post2359813
Peter
Old 05-14-2020, 04:46 PM   #40
forestgirl's Avatar
2019 30' International
Battle Ground , Washington
I thought it odd as well that it has to be rotating but I used it all the time in our 22’Sport and opted to stay with the convection option and not the oven in our 30’.
I bake artisan bread in a French white Pyrex and you may have to adjust cooking times. I love, love this oven. It doesn’t go to 450° but because it’s convection I put my bread in at 425° and it comes out crusty with a great crumb after 40 minutes. I also bought silicone 8” square pans, as well as a silicone loaf and tart pan. The silicone can go up to 500° and I’ve baked a lot in this oven with the silicone and again, everything comes out great. I begin to check things approximately 10” before it should be done as convection cooks things a little faster. I’ve made lasagna in the two 8” pans. A little more work but that’s okay.
I bought some various sizes of metal cooking stands (like the kind you use in the Instantpot) and I use those when I need different heights to bake and I bought them at WM for $5. Great deal. I have not shut off the turntable as both manuals ( our Sport was a different model, a Cuisinart) recommend not to ever do that.
forestgirl is offline   Reply With Quote
Microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 9 05-04-2023 08:36 AM
Convection microwave as only oven? phbarnhart Stella's Kitchen 41 07-15-2014 05:17 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
Batteries, Baking Soda, Leaf Blower & Mice tylerbear Batteries, Univolts, Converters & Inverters 4 09-13-2008 06:13 AM
Baking Cookies azflycaster Stoves, Ovens & Microwaves 8 07-20-2008 12:18 AM
