Old 11-23-2022, 12:34 PM   #1
Elkins , Arkansas
Magic Chef 1965 318 oven wonít light.
Hi Iím new and would be so grateful for some help. Iím working on a Magic Chef 1965 3 burner cook stove model 318. It appears to be in good shape, nothing I can see missing, excessively rusty or dirty, or pinched. The range worked well without any work whatsoever. But I canít get the oven to light or even seem as though gas is getting to it. Iíve had a 50s vintage stove, but not a 60s RV stove, and I donít really even know what Iím looking for. Iíve looked for other forums and manuals but nothing seems like it fits my model. Iím inclined to believe that maybe thereís an adjustment Iím overlooking. The only shutoff I see is the B valve under the range which is vertical with the line, so I assume on. Turns off an on easily. Iíve taken the oven knob off and thereís a screw but I couldnít tell that it did anything. On the model label it says for please gas which is what Iím using.
I would appreciate any help, diagrams, or input.
Thanks so much in advance
Kaycocondery is offline   Reply With Quote
Old 11-23-2022, 03:51 PM   #2
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Mine won't light either in a 67.
From what I've read on these forums there is a part that goes bad in them. + It is no longer available.
I made a nice shelf & the oven became storage.
It's hard to imagine baking something while camping. Especially when the out of doors is so close.
Dingo Girl is offline   Reply With Quote
Old 11-23-2022, 08:30 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
It is likely that the thermocouple is worn out. The thermocouple makes sure that the pilot light is on before letting gas flow to the oven "burner". You should be able to replace this with a current day device. I would remove it from the oven and take it to a mom-and-pop appliance store. Maybe the web. You might have to drill new mounting holes. Here is a replacement I found online that might be adaptable. https://www.easyapplianceparts.com/P...0Range%20Parts
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 11-24-2022, 10:25 AM   #4
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
oven pilot light
The thermocouple is not the likely culprit in this situation. In these Magic Chef units, the pilot light lights another pilot light that then heats the thermocouple. In this case, the first pilot is not lighting so the thermocouple is not in play.
There is a pilot system shut-off located under the stovetop. Open-hinged stove top. Just inside the cabinet behind the exterior control knobs, you will find a 1/2" dia. brass ball valve. This slotted valve needs to be turned 90* to open. Then light the pilot light. It may take 30 seconds for the gas to move through the small dia, aluminum tubing to the pilot. After the pilot has been lit it also takes 1/2 to one minute for the system to light the burner after turning the temperature control knob.
Be sure to turn off the ball valve under the stove top because the system has no autopilot light gas shut off. If the pilot goes out the gas to the pilot will not shut off automatically.
Greg Anderson
Wisconsin
gdanderson is offline   Reply With Quote
1971 Magic Chef oven won't light Christalm Stoves, Ovens & Microwaves 0 08-19-2021 02:37 PM
Through Nevada on 1-93 & Highway 318 - Recommendations? earlyescape On The Road... 6 05-06-2018 05:56 PM
Will my '99 Dodge Durango 5.2 liter 318 V8 Magnum pull my 1972 27 ft Airstream? mtviewnana Towing, Tow Vehicles & Hitches 18 09-26-2013 08:30 AM
Magic Chef, Robert Shaw oven won't work 63 Safari MT Stoves, Ovens & Microwaves 3 06-02-2009 04:41 PM
Magic Chef oven won't light, revisited Safari64 Furnaces, Heaters, Fireplaces & Air Conditioning 8 12-23-2005 07:14 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
