Old 01-17-2023, 10:54 AM   #1
Genebuilder's Avatar
2017 25' Flying Cloud
Celina , Texas
Furrion Stove Top Grill Embarrassment
For those of you who spent beaucoup bucks on a Globetrotter only to find an embarrassingly inadequate stovetop grill on your Furrion range, have you done anything to correct the situation? Apologies if this topic has already been (dis)cussed elsewhere.
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
Genebuilder is offline   Reply With Quote
Old 01-17-2023, 11:31 AM   #2
2022 27' Globetrotter
DALLAS , TX
Hey Gene,
Take a look at the grates shown here. I believe they will fit your current Furrion stovetop.
https://www.etrailer.com/question-511005.html
I used these same grates on my 2022 Globetrotter 27FB Twin Dometic Oven/Stovetop.
Additional information:
You can get mocap black silicon caps for the legs on the cast iron grate (to prevent scratches on the dometic stovetop). You just use a knife to shorten them a bit.
The part number for the black mocap high temp silicon caps: MEC 148-1
The black caps are available on amazon for about $21 for a pack of 50 plugs
You can plug the holes left from the original Dometic grate using 1/4" nickel plated steel plugs from McMaster Carr. These come in a pack of 50 for $13.
The part number for the nickel plated steel caps is 9563K41
foobar is online now   Reply With Quote
Old 01-17-2023, 01:43 PM   #3
DALLAS , TX
Forgot to mention that etrailer will price match. You can find some other sources of the grates at significantly lower prices and provide that information to etrailer.
Here is another airforum thread on upgrading the grates on a furrion oven/stovetop (vs the Dometic stove that I upgraded):
https://www.airforums.com/forums/f53...ch-232989.html
Old 01-17-2023, 02:18 PM   #4
DALLAS , TX
Gene, if I recall correctly, you are just up the road from me here in Far North Dallas. If you want to lay eyes on my grates before you purchase your own, just send me a PM and we can arrange to meet at my trailers storage site in Lewisville.
Old 01-17-2023, 02:27 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
The Dometic Grates are pretty anemic to say the least. The Furrion cast iron grates drop right in and are a wonderful replacement.
ID:	427239   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-17-2023, 02:40 PM   #6
DALLAS , TX
GMFL beat me to it. I was hunting around for my photos of the Dometic grill upgrade project while he was busy uploading his, lol.
Please note that the stove being upgraded is a Dometic, not a Furrion. Your challenges might be different.
Here are my pics:Click image for larger version
ID:	427249Click image for larger version
ID:	427250Click image for larger version
ID:	427251Click image for larger version
ID:	427252Click image for larger version
ID:	427253Click image for larger version
ID:	427254Click image for larger version
Old 01-17-2023, 03:08 PM   #7
Celina , Texas
Thanx guys, very helpful.
Old 01-18-2023, 09:47 AM   #8
2015 30' International
Escondido , CA
Ronnie, any suggestions for a cast iron upgrade on the crappy Atwood stovetop grates that sag when they get too hot and the black paint burns off of them?
Dave Sexton
dsatwork is offline   Reply With Quote
Old 01-25-2023, 09:56 AM   #9
2022 23' Flying Cloud
Watsontown , Pennsylvania
Wow - another first-world problem. But I need those cast iron grates! Thanks for the info!
Amazon has everything cheaper and faster - except a lot of this RV stuff. I did find them at Panther RV for $140.
So after more research, I see some of these Furrion stoves come with really cheap wire grilles. Our grilles are much nicer and have square components but are not cast iron.
Still like the cast iron a lot better but the RV world is it's own universe of options and variations. My model number from the actual stove in our Airstream matches none of the numbers on any of the websites that list the stoves the grilles fit.
ricjones is offline   Reply With Quote
Old 01-25-2023, 01:26 PM   #10
DALLAS , TX
I put Furrion cast iron grates on a Dometic oven/stovetop.
Of course, Furrion will not list the Dometic as a stove for which these grates will fit. The reverse is also true. Dometic does not list Furrion grates as a suitable replacement.
So, you have to assess the dimensions and burner locations of the replacement grates vs your current stovetop and determine if the grates will actually work anyway. This is why I posted the link to the etrailer measurements for the replacement grates in my first posting on this thread.
In my case, the only thing that isn't perfect is the location of where furrion placed the burner isn't a perfect match for the locations of the burners on the Dometic stovetop. But it works well and still looks great.
Old 01-25-2023, 03:41 PM   #11
2022 25' Globetrotter
Hanover , Pennsylvania
We found the Dometic cast iron grates on ebay for $90 last fall. Might be worth a try.
Took maybe 20 min to change.
Last Mango is offline   Reply With Quote
Old 01-26-2023, 05:53 AM   #12
2020 25' Globetrotter
2016 22' Sport
Lecanto , Florida
great removal
do the original dometic grates just pull out or is there a trick to removing them?
WDEL is offline   Reply With Quote
Old 01-26-2023, 06:19 AM   #13
DALLAS , TX
The wire frame grates simply pull out vertically.
There are silicone grommets that the grates slide into, these will need to be removed as well. Recommend filling the holes with the McMaster-Carr plugs that I specified in an earlier post in this thread in order to prevent goop from cooking from falling into the holes.
Stove / Oven - Lippert or Furrion? Frank&Mike Stoves, Ovens & Microwaves 23 11-07-2022 01:53 PM
Furrion Stove Glass Top GBandBONES 2016 - Current Flying Cloud 3 06-09-2021 10:02 AM
Furrion 30A and TV inlet upgrade questions Bluto Electrical - Systems, Generators, Batteries & Solar 28 06-09-2016 08:31 PM
Dometic Cooker Stove Oven Grill 1964 Safari lawrence1111 Airstream Classifieds 0 12-13-2013 06:53 PM
