Fs21db4a-bl
Received the Furrion Model FS21DB4A-BL on 3AUG2020. Unpacked.
Wanted to operate unit outside prior to install... prudently paranoid.. connected to Propane cylinder for successful test of cooktop burners and oven. Outside of oven cabinet only heated to 115 degrees. Passed propane sniffer test.
Installed same 4AUG2020, in Mjolnir. Passed propane sniffer test.
All fired up perfect flame. Note: there is no air adjustment shutter on any burner.
Load of biscuits in an 8” black iron skillet perfect at 1730hrs. 450 degrees setting within 10 degrees Maintained temp with 15 degree variation. 4 minutes longer than home propane range.
Installation required an MIP to flare adapter. Use the “yellow” sealant and tape. Careful to hold the regulator because the threads are sealed with a white color RTV so seal easily compromised.
Blue lights very bright... plenty for night light. Maybe too bright. Switch gives on cooktop dial light, or dials AND oven lights.
Glass top is smoky gray.. folds and stows nicely.
Cast grates give very flat cooking surface and very “rough”... so it holds pots firmly. Caution: aluminum “Jiffy Pop” pans or Magnalite aluminum will leave Metal residue on the grates if shaken making popcorn. Heats to 500.. but it takes a while.
Peace and Blessings..
Channing
WBCCI# 30676
