Naturally the easiest solution is to go with same; however, I had an older model Airstream '06 and went with a totally different brand and upgraded too. I had to cut the opening wider and deeper and also run electric and make an aluminum bracket for the base to sit on as per instructions. It is a Suburban Elite 3636A. The actual stove cavity and old model almost had identical size but the top of this one was wider as it has a top or attached cover part. so, the cabinet part had to be adjusted to be bigger. I use my stove and oven so I wanted a good one. The burner adjustment control on this one is way better than the one it replaces.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
