Old 02-16-2019, 04:56 PM   #1
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Dometic Propane stove top.
Is anyone happy with the Dometic three burner stove top? This is the new top that has wire racks for each burner. Our signature 27 had the full porcelain grate.
The problem I have is that the pots will slide off the burners! Ok, yes we are level, but try to boil a large pot of water for pasta and as the rolling bubbles develop, the pot starts moving off the burner. Fortunately, it always seems to move toward the back. It's to the point that it may be dangerous if you don't watch. Frying pans are already too large for the burners, but give them a bump and they get off balance and tip.
Has anyone found a solution for this? I have purposely put a frying pan or two next to the pot to "wedge" it so it won't move. It is getting a bit ridiculous. I'm ready to add some steel weights to the top of the cooktop to add more support for the pans.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 02-17-2019, 12:02 AM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
We use a portable induction cooktop for most things resting on the closed lid of the propane stone. These cost less than $100 but you might need to upgrade your inverter if you arenít plugged in. Boils water twice as fast, simmers well, a breeze to clean.
daleyocum is offline   Reply With Quote
Old 02-17-2019, 07:07 AM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
We have an induction cooktop also. Your right, it will boil water very fast. It still does not solve the stove issue as we sometimes have 2 or three pots going at a time.
Did Dometic even test this thing??
Old 02-17-2019, 09:20 AM   #4
daleyocum's Avatar
Portland , Oregon
Now I see. We were thinking of switching TO that cooktop from the one with the heavier grates and metal hood because of the flat top and auto ignition. Maybe not!
We’ve also thought about getting a double induction cooktop.
Old 02-17-2019, 09:44 AM   #5
SewStream's Avatar
Sanford , Arizona
I use my All-Clad cookware (skillets and pots raided from our B&S kitchen) on the Dometic CU434 range in our GT. I have not had an issue with the stovetop using this cookware. In fact, I find that my 12Ē All-Clad skillet works great on the front burner. The long All-Clad handles are not an issue for me either. I also use a small cast-iron griddle on the front burner. Perhaps because my cookware has heavier bottoms I am not experiencing the issues you describe with the cooktop?
I use the stovetop and oven most every day as we travel full-time in our Globetrotter. If Iím not using the stovetop, then I am using my 3 QT mini InstantPot. BTW - I always cook inside - by choice as I find the range hood sufficient for venting moisture outside the coach.
SewStream is offline   Reply With Quote
Old 02-17-2019, 09:54 AM   #6
SewStream's Avatar
Sanford , Arizona
If it would be helpful, I will take photos next time I am using the cooktop. Let me know...
Old 02-17-2019, 10:05 AM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
We like our dometic CU-434 just fine. We donít have issues with things sliding off.
We also use a little electric kettle for quick boiling of small quantities of water for tea, soup, etc...
It looks like you have a 5 gallon pot on that little stove - do you often cook spaghetti for 20 people? I can see why a pot that big could cause some problems with the weight of all that water.
wulfraat is offline   Reply With Quote
Old 09-06-2019, 07:43 AM   #8
2019 27' Globetrotter
WARRINGTON , Pennsylvania
Dometic Stove Grate DIY Upgrade
We also were disappointed with the small wire grates on the Dometic stove in our 2019 Globetrotter. So I purchased a grate that was similar in size and modified it to fit.
I purchased the Suburban Delux Cooking Grate from RV Adventures (better picture on Amazon). The quality is not great, so, if you go this route, you may want to purchase two. I cut out the bars on the left and right, leaving the "feet", and then trimmed each foot by about 2 millimeters. I sanded the rough spots, used gloss black stove paint to spruce it up, and added rubber end caps to keep the feet from scratching the stove top. Finally, I ordered cabinet plug bumper stops to plug up the grommet holes to keep gunk from getting down inside the stove.
I will be interested to hear if anyone else has found a cast iron grate that works. Also, people rave about the Furrion stove found in other Airstream models; I'd be interested to see if anyone has swapped out their Dometic for a Furrion.
Name:	stove grate 1.jpg
ID:	351433   Click image for larger version
Name:	stove grate 2.jpg
Name:	stove grate 3.jpg
ID:	351435   Click image for larger version
Name:	stove grate 4.jpg
hdavis40 is offline   Reply With Quote
Old 05-20-2020, 07:57 AM   #9
2019 33' Classic
Douglas , Alaska
The Magma stackable cookware stainless/ceramica set is perfect for this stove top and it stores nicely in the drawer below in our 2019 AS Classic - https://magmaproducts.com/product/a10-366-2/a10-363-2
WanderGators is offline   Reply With Quote
Old 09-15-2020, 07:24 PM   #10
2020 25' Globetrotter
Malibu , California
Finally arrived, new grates
Had to grind a bit to get past screw heads. Loving it
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
Garfish is offline   Reply With Quote
Old 09-16-2020, 05:32 AM   #11
Hi Garfish - Those grates look terrific! Are they cast iron, and, most importantly, where did you find them?
Hugh
Old 02-07-2021, 05:39 AM   #12
2020 33' Classic
Fort Pierce , FL
What model/where did you purchase your grate for your Dometic CU-434 stove?
sesmith06 is offline   Reply With Quote
Old 02-07-2021, 06:03 AM   #13
2020 33' Classic
Fort Pierce , FL
For those interested in the Dometic CU-434 stove top grate replacement this is where I found them. I read through the reviews and those that purchased them seem very happy. While they are a bit pricey, it is a LOT cheaper and less painful than a visit to the ER for burns! I hope this helps! https://www.etrailer.com/Accessories...RE21SA002.html
Susan
2020 33’ Classic FBQ
2013 Toyota Tundra 5.7L
Old 02-07-2021, 08:38 AM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
After trimming the "fingers" over each burner to be just outside of the burner head, notching one side for the screw heads as the other side can be slid in under the screws, I also ground bevels on the edges and feet to better fit the curvature of the stove on both side of the grates.
Really like these trailer grates. Note that I put stainless screws into the remaining rubber grommets from the original supports.
The second stove was a better job than the first.....
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 02-11-2021, 10:04 AM   #15
2016 22' Sport
2018 25' International
Chino Hills , California
Please share link to purchase suburban deluxe cooking grate. This will work well. Thank you for sharing information.
As I said on many occasions Airstream’s are amazing. The real silver lining is the people you meet on this journey.
Safe journey. See you down the road Neighbors.
Luke Grisott is offline   Reply With Quote
Old 02-12-2021, 08:23 AM   #16
Dometic Stove Top Grate
Here are two links to the Suburban stove top grate.
RV Adventure
https://www.adventurerv.net/kit-deluxe-grate-p-36509.html
Amazon
https://www.amazon.com/Suburban-521121-Deluxe-Cooking-Grate/dp/B00R6KMBW2/ref=sr_1_1?dchild=1&keywords=suburban+stove+grate& qid=1613143269&sr=8-1
However, as you may have seen in some other threads, there is a cast iron option by Furrion. I found a set on line for $68, and eTrailer matched the price.
https://www.etrailer.com/Accessories-and-Parts/Furrion/CFSRE21SA002.html
I found it to be an exact fit, but some folks indicated the need to grind out notches in the side where the sides bump up against screws. I can slide mine under the screws. Someone also mentioned rounding the feet to keep it from scratching the stove top - great idea. I also filled in the grommet holes from the original wire grates with stainless steel screws set in high temp silicon.
While the Suburban grate option worked fine, the cast iron grate is a much nicer option.
Good luck!
Old 02-17-2021, 06:22 AM   #17
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
cast iron grate
We found this *RV CAMPER FURRION/GREYSTONE RANGE OVEN COOKTOP PORCELAIN GRATES BLACK FREE SHIP
( 353089702827 ) on eBay, $55 shipped
rbs is offline   Reply With Quote
Old 03-05-2021, 10:36 PM   #18
wulfraat's Avatar
I took the plunge and bought the furion grate off eTrailer.... installed my new grate this evening. Zero clearance sliding it in under the screws. Really tight fit and scraped up the sides of the flange as it slid in. Oh well I guess. The scrapes are covered up by the grate itself, except for the very front of the flange.
Does anyone else have a super tight for with theirs? Itís actually going to be a bit of a PITA to slide out and clean.
Old 03-06-2021, 05:31 AM   #19
2017 19' Flying Cloud
Columbia , Missouri
My pans slide too! Of course I use the front burner the most, & I have found depending on my pan size, it will do better on a back burner. Sometimes I'm just not exactly centered on the burner to make it stay. My other problem beyond this is the ceramic coating of the grating is all cracked & will eventually fall off. It's even the second top I've had with the same problem- JC replaced the first under warranty. I'll have to put a new top on at some point. Never had this happen with previous rv's
fossil5775 is offline   Reply With Quote
Old 03-07-2021, 05:47 AM   #20
2020 33' Classic
Fort Pierce , FL
Ours was tight. My hubby grinder a tiny bit and it is snug, but easy to lift off. At first it scratched the stainless steel a little which bothered me more than my hubby which is very unusual. He was confident the scratches could be polished out. The nice thing about it being snug is no shifting during travel. I’m just happy at feeling safer when cooking.
Susan
2020 Classic FBQ
2018 Airstream Three burner propane stove top redhat200 Airstream Classifieds 0 08-27-2018 04:45 PM
Propane Stove Top Mtipton49 Airstream Classifieds 0 07-16-2018 07:42 AM
Faint propane smell near stove top SeaLevel LP Gas, Piping, Tanks & Regulators 13 12-18-2017 05:54 PM
Heat -- using propane stove top burners or oven Jim Lee On The Road... 25 01-24-2014 05:12 AM
