Old 03-07-2021, 06:36 AM   #21
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by sesmith06 View Post
Ours was tight. My hubby grinder a tiny bit and it is snug, but easy to lift off. At first it scratched the stainless steel a little which bothered me more than my hubby which is very unusual. He was confident the scratches could be polished out. The nice thing about it being snug is no shifting during travel. Iím just happy at feeling safer when cooking.
Susan
2020 Classic FBQ
2013 Toyota Tundra 5.7L
Cool thanks. Do you find yourselves removing the grate to clean underneath or are you able to manage with the grate in place?
wulfraat is offline   Reply With Quote
Old 03-08-2021, 03:19 AM   #22
2020 33' Classic
Fort Pierce , FL
Dometis Stove top
I remove them. Once the tight sections were grounded down it makes it easier to remove. We placed hex screws in the grommets where the original thin wire grates were. They fit snug but can be removed to be cleaned and donít have the slots like a screw or Phillips head. Now to tackle a solution to the center vent!
sesmith06 is offline   Reply With Quote
Old 05-16-2022, 10:42 AM   #23
2022 27' Globetrotter
DALLAS , TX
The following info might help someone else trying to follow the same path.
Home Depot sells the Lippert Cast Iron grate CFSRE21SA002 (replacement for the Furrion grate #723403) for $40 cheaper than etrailer
You can get mocap black silicon caps (instead of bright orange) for the legs on the cast iron grate (to prevent scratches on the dometic stovetop).
The part number for the bright orange mocap silicon caps: MSC 148-1
The part number for the black mocap silicon caps: MEC 148-1
Both the orange and black caps are available on amazon for about $21 for a pack of 50 plugs
You can plug the holes left from the original Dometic grate using 1/4" nickel plated steel plugs from McMaster Carr. These come in a pack of 50 for $13.
The part number for the nickel plated steel caps is 9563K41
foobar is offline   Reply With Quote
Old 05-23-2023, 05:26 PM   #24
Saint Regis Falls , NY
Dometic 2 Burner Cook Top PI8022
Trying to find Mfg Part Number 1053107688 Burner and Valve Assembly. We had a crack in the tube and nut. It appears Dometic no longer makes drop in ranges and the parts are out of production. Any ideas who might have this part?
RichardJ is offline   Reply With Quote
2018 Airstream Three burner propane stove top redhat200 Airstream Classifieds 0 08-27-2018 04:45 PM
Propane Stove Top Mtipton49 Airstream Classifieds 0 07-16-2018 07:42 AM
Faint propane smell near stove top SeaLevel LP Gas, Piping, Tanks & Regulators 13 12-18-2017 05:54 PM
Heat -- using propane stove top burners or oven Jim Lee On The Road... 25 01-24-2014 05:12 AM
