Old 02-16-2021, 07:53 PM   #1
2019 23' Flying Cloud
Idyllwild , California
Dometic LP Range / cooktop
Hi All,
2019 AS Flying Cloud. Furnace, water heater and fridge all work fine on propane. Propane tank full. But, after working fine for a year, now neither cooktops nor oven will work at all. I turn on the burners and the oven, but can't smell or hear any coming through the stove. Is there some sort of hidden gas shutoff that could be causing this? Or, does anyone have advice on other ways to trouble shoot this?
it did get down into the teens a few nights in a row, but that's not super cold by most standards and I did have heat running in the trailer.
Thank you!!!
Mike
Idyllmike is offline   Reply With Quote
Old 02-17-2021, 10:03 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
If everything else is working, Iíd start looking for any exterior damage to the propane line under the trailer and then likely would have to uninstall the range and reseat connections. There may be an internal safety switch that tripped for some reason. Usually disconnecting and reconnecting resets it.
I am an amateur when it comes to propane though. Someone may have more ideas before running down the rabbit hole of uninstalling the range.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-24-2021, 01:15 PM   #3
Thanks! I took out the range, and found that the propane line was very long behind it and must have kinked at some point? I then found that the regulator on the Domestic stove went bad somehow, even though less than 2 yrs old. Replaced the regulator, unkinked line, stove and oven working again.
Stand alone Dometic cooktop in new Classic NicheVintage 2016 - Current Classic (all lengths) 1 09-19-2020 08:41 PM
Cooktop and oven or range? ArtisanAir Stoves, Ovens & Microwaves 14 03-16-2016 08:05 PM
Dometic recessed cooktop? jtfink Stoves, Ovens & Microwaves 2 08-15-2015 06:03 AM
Magic Chef range - LP slide-in cooktop/convection oven swap... MaxAB Stoves, Ovens & Microwaves 5 10-04-2010 09:26 AM
Replace range/oven with range/microwave rkconway Stoves, Ovens & Microwaves 2 01-13-2009 03:58 PM
