Old 06-04-2023, 07:09 AM   #1
South Burlington , Vermont
Do I Need (can I get) a Range Top Thermocouple?
2011 Bambi Sport
The Range Part is listed in the manual as:
690576 Cooktop-2 Burner SMEV 8022 ST.Satin (with no other parts listed)
One of the two burners won't stay lit when we release the knob pressure. I think that probably indicates that the thermocouple is no longer correctly sensing heat and tells the gas to shut off? At least it seemed plausible enough to just replace that part, which I had hoped was cheap, easy to find and easy to replace.
Perhaps not. My manual doesn't even list that part.
In new manuals (2020) I see the same base part plus the other parts and it's listed as:
690576-102 Thermocouple W/250mm Wire For 690576 Cooktop
But when I search all that, I don't see the part anywhere. It just brings up igniters and entire range replacements.
Sorry if I'm being thick but is there some reason that part is hard to find, and isn't even listed as a part for my model year? It's hard to believe you just need to replace the whole unit.
Thanks for any insight!
TomPiper is offline   Reply With Quote
Old 06-04-2023, 07:11 AM   #2
Originally Posted by TomPiper View Post
2011 Bambi Sport
Sorry - in the 2020 manual it also lists 690576-111 Thermocouple by itself. But same issue, a search on that doesn't bring up just that part for me.
Old 06-05-2023, 05:58 AM   #3
2020 19' Caravel
Ammon , Idaho
I have had that issue with my residential gas fireplace. Gentle cleaning with fine steel wool corrected the issue. That would be an easy first step if you have not tried that already.
OutdoorIdaho is offline   Reply With Quote
Need a thermocouple for 2005 Westy Wiselion06 LP Gas, Piping, Tanks & Regulators 1 04-04-2023 12:08 PM
Range domestic cu434 oven thermocouple repair pliddell General Repair Forum 2 02-03-2023 05:52 PM
Airstream Cook Top and Range Top Covers - Michigan JMatson1111 Airstream Classifieds 0 03-15-2022 10:04 AM
Thermocouple and Thermostat....HIGHWAY ROBBERY!! Alan and Mardel Water Heaters, Filters & Pumps 2 12-23-2003 02:41 PM
