Old 09-19-2024, 09:35 AM   #1
2017 25' Flying Cloud
Palm Coast , Florida
Cut the dickens out of my thumb on Stovetop lid
Was wondering if anyone else is having issues with the Stovetop Lid on my 2017 Flying Cloud? I cut myself several times in the past but it wasn't worth the mention. I had to go to hospital last night and 5 stitches later still have a thumb. That said - Any thoughts on making the edges less sharp? I know this is a silly question but I thought I would ask. Thank you all.
DBHent is offline   Reply With Quote
Old 09-19-2024, 10:24 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Is it stainless steel? If so, I'd be reaching for a fine-tooth metal file to start, followed by a pass with some 400 wet/dry sandpaper to create a slightly rounded edge.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 09-19-2024, 01:30 PM   #3
2021 23' Flying Cloud
2024 25' Globetrotter
Louisville , 40222
Stovetop
We had this same issue on our 2024 Globetrotter stovetop. First trip my wife sliced her hand simply wiping the counter and she brushed up against the metal side trim and is was razor sharp. Already had a set appointment at JC and they could not get the unit to flush so they replaced it with a new one. Still sharp and I actually called manufacturer to see if perhaps they made a trim but they did not. I will most likely find a rubber trim piece to slip on the metal trim rails,
Deholden is offline   Reply With Quote
Old 09-20-2024, 05:13 AM   #4
Yep that is what I was thinking too. Thanks. Sorry you had the same issue. I hope your wife is ok.
Old 09-20-2024, 06:23 AM   #5
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
You might consider a bead of silicone around the entire sharp edge to cover the edge.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 09-20-2024, 09:13 AM   #6
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
I second the above suggestion. Or some type of moleskin if the sharp edge isn’t going to be over the flame.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 09-20-2024, 09:31 AM   #7
Smile
It is on the front edge of the stove lid so not close to the fires. The sides are nice and smooth, but the front is actually like a sharp knife edge. I don't know why they would leave it that way in the first place. I am thinking a piece of rubber tube cut halfway through so I can push onto the sharp edge and keep my hands from harm in the future. Thank you all for your ideas.
Old 09-20-2024, 12:23 PM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Used a Dremel to blunt the edges. That should have been done by the manufacturer. Probably no one has sued them yet.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
Hermes is offline   Reply With Quote
Old 09-25-2024, 09:30 AM   #9
2019 25' Flying Cloud
Sequim , Washington
I had a similar experience on my first day of a brand new Airstream ownership 10 years ago. While trying to adjust the dinette table on our 23’ FC I severely cut my index finger on a very sharp metal edge of the adjusting mechanism that was under the table and thus not visible AND was clearly cut with some tool during manufacture and not in the least sanded down to remove a razor sharp edge. Just one of dozens of poor quality control on Airstreams that I (and many others) have documented over the years.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 09-25-2024, 09:44 AM   #10
2022 27' Flying Cloud
2024 27' Globetrotter
Irmo , South Carolina
I was in JC with my 2024.0 Globetrotter in June. They replaced the original Dometic(?) stovetop with the newer GE. The Dometic would not sit flush with the counter top. The techs mentioned they had another GT owner in recently who got cut on the Dometic.
The GE stovetop fit perfectly and sits flush. The edges of the GE are not sharp and are powder coated. The GE has a more substantial cook top grate but does not have a cover. There's a glass cover for the GE available through 3rd parties.
BMitch8 is offline   Reply With Quote
Old 09-25-2024, 10:24 AM   #11
casarodante's Avatar
2012 31' Classic
Golden Valley , Arizona
Perhaps this?
https://www.amazon.com/dp/B07PRHG81Z...sin_title&th=1
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 09-25-2024, 12:48 PM   #12
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
use a fine file to smooth the edge and remove the sharp corner
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 09-25-2024, 01:02 PM   #13
ntsbltsrvits
Cowbell's Avatar
2015 27' FB International
2016 30' International
Eagle , Idaho
I’ve cut myself also
I complained about the sharp edges to the rep working at the Quartzite RV show in January 2023. Hoping they’ve fixed the problem by now. Just an extra step of about 30 seconds would do the trick.
Cowbell is offline   Reply With Quote
Old 09-26-2024, 07:04 AM   #14
i purchased some rubber trim that slips over the edge and sticks. It works and now I have plenty for next cut if that happens. Thank you for your note
Old 09-28-2024, 11:44 AM   #15
2015 23' FB International
Mount Pulaski , Illinois
Sharp Edge on Stove lid cover
We have a 2015 International 23'. We had the same issue with this very sharp edge on the stove lid cover. We used 100 grit wet or dry sandpaper to smooth the sharp edge, otherwise we too would have been pulling out the first aid kit, or visiting the ER.
PrairieRV is offline   Reply With Quote
Stovetop lid brackets? BettyJane 1965 - 1969 Overlander 2 09-19-2016 07:06 PM
The "Rule of Thumb" on Tire Life RangerJay Tires 27 03-22-2007 09:58 AM
bulldog hitch with thumb lever emo59 Hitches, Couplers & Balls 2 03-14-2007 08:15 PM
'48 Westcraft with its thumb up! fabofabo Our Community 0 06-01-2005 01:36 PM
Thumb-up for MaxxAir femuse Roof Vents, Skylights & Fans 0 04-18-2003 11:15 AM
