Old 09-09-2015, 03:55 AM   #1
Buttons on Baraldi range hood
On our maiden voyage this past weekend with our 2016 International, both slide buttons on the Baraldi range hood fell inside the unit. I had to grab them with a needle nose pliers to pull them out. Has anyone else had this problem? If so, can you please advise on how to fix it? Yes, I know that it's under warranty, but I'd rather fix it myself, if possible, than tow the trailer to the nearest dealer which is 1 1/2 hours away. Thanks.
loberg is offline   Reply With Quote
Old 09-09-2015, 04:47 AM   #2
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
My wife was able to reach inside to hold the base while I pushed the trim piece on, you must make sure the switch components line up. We had Airstream look at ours and they found installing the trim upside down provided a more secure fitting. It has worked so far and we had put ours back together twice before. Bad design
rbs is offline   Reply With Quote
Old 09-09-2015, 06:01 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We had the same issue on our 2014. We had Airstream replace the switch with a new one when we were in Jackson Center and the new one seem to be beefier than the original. It is apparently not that hard to replace if you are handy. I would have your dealer send you the replacement switch set and then you can do this yourself and save the trip to the dealer.
Bob Martel
WBCCI# 5766
Old 09-09-2015, 12:12 PM   #4
2020 Classic 33
Box Elder , South Dakota
See this post in a link. Easy to fix if the prongs haven't broken off.
http://www.airforums.com/forums/f44/...ml#post1661523
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 09-09-2015, 01:45 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
yep ...
Old 09-10-2015, 11:34 AM   #6
Fulltimer Oldtimer
2015 30' International
Marietta , Ohio
We were two weeks into our new Rivet Life and the same thing happened. Dealer probably should've warned us but it is a cheaply made switch it seems. Hope to replace not fix because one of the posts are broken.
The one link the other replier made is a good one.
Mark
marcusmark is offline   Reply With Quote
Baraldi Vent Hood power switch ghaynes755 Stoves, Ovens & Microwaves 13 06-20-2020 10:39 AM
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Slightly used Baraldi Range Hood Snaken49 Airstream Classifieds 0 01-26-2015 02:37 PM
LED Conversion: Baraldi Range Hood Lights TinTin Stoves, Ovens & Microwaves 5 07-13-2014 02:38 PM
Baraldi Range Hoods dznf0g Stoves, Ovens & Microwaves 1 04-25-2013 05:13 PM
