10-14-2006, 04:04 PM
Dryden
, Michigan
67 caravel furnace...HELP...
Can anyone tell me how to seperate the furnace from the flue pipe. I'm trying to remove the furnace and replace the floor but can not see how to seperate the pipe. The outside fixture is loose from the outer skin, the furnace is loose from the wood cabinet, I can find no screws on either end. The outside fixture is spot welded together so other than cutting the end off I can't find any other recourse. Any suggestions would certainly be appreciated.
Gene
10-14-2006, 05:35 PM
1967 22' Safari
1960 Caravel
Edmonds
Hi Gene,
The tube connecting your furnace and the exhaust flue may have rusted and become one. The connecting spot is in the wall, so try to get behind the furnace and spray some rust solvent on the pipes to loosen them, and/or use as much careful brute force as you can. Good luck!
Mel
10-14-2006, 06:55 PM
Dryden
, Michigan
Furnace
Thanks, I'll try some spray and reply back.
Gene
10-15-2006, 10:38 AM
Dryden
, Michigan
Furnace
Well, I sprayed the inner pipe real well, let it sit for an hour and then started to work it over, it appears the someone in the past had the unit out and welded the flu pipe to the intake/exhaust deflecter on the outside. So, with a chisel I was able to cut the deflecter off the flu pipe( 15 or so spot welds ) and the unit came right out. Now on to removal of the rest of the floor.
Gene
10-18-2006, 12:37 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
Hydro Flame
So I was wondering...whatcha goin to do with the old HydroFlame ? I may be interested in it if you are tossing it out.
Chris
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
10-18-2006, 08:12 AM
1968 17' Caravel
Battle Ground
Are you collecting old hydroflames, Chris? You can have mine
Stephanie
10-18-2006, 08:50 AM
2003 22' International CCD
Kiln
, Mississippi
I would like the outside part of your hydroflame. Mine is trashed and I would like to get a new one.
PLEASE PLEASE PLEASE
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
10-18-2006, 09:21 AM
1968 17' Caravel
Battle Ground
Well, if you're going to beg I'll PM you...
Stephanie
10-18-2006, 11:18 AM
1966 17' Caravel
Seattle
66 Caravel Furance
I have a Hydroflame furance as well.
I'm completing my renovations before the Beverly Beach get together.
Let me know if I should bring it. The cover is in great shape. The furnace would be great for parts. Sorry, I never tired firing "her" up. I replaced the furance w/ a Wave 8.
K
10-18-2006, 02:55 PM
1968 17' Caravel
Battle Ground
Mine worked great until it blew up, then I replaced it with a modern heater just like the new bambi's have. It has a fan and is so noisy compared to before. Nothing beats the old hydroflame for quiet and warm.
Stephanie
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
72 Airstream International Furnace parts
loechli |
Furnaces, Heaters, Fireplaces & Air Conditioning |
7 |
08-20-2008 07:17 PM |
Furnace stuff...
Chuck |
11 |
12-02-2002 05:36 PM |
Jingle Bell Furnace Fix
Pahaska |
5 |
11-19-2002 09:59 PM |
Forced Air furnace
Joan D'Andrea |
16 |
11-02-2002 09:41 PM |
Furnace problems...
Andy R |
3 |
04-01-2002 08:29 PM |
