My first observation is that a conventional 3-way Dometic can be used on inverter power if sufficient solar and battery reserves are present, but it's very inefficient because its A/C option was intended for shore power, and designed without conservation in mind. Mine is very small, a 2351 model, and it seems to draw a fairly steady 10 amps when I use it that way (theory says it should drop off when it cycles, but in my test runs, I didn't see it do that). This means it can only be running on inverter while the sun is high in the sky and the batteries are recharging at as great or greater a rate than the unit is drawing. I suspect that any multi-source unit that includes propane as one of its options will be designed similarly, but I'd love to know if that's NOT the case.
The Sunfrost F10 looks very interesting and it openly states its daily energy needs at 55 amp-hours (70 degrees ambient), which is really good compared to my Dometic. 55 amp-hours would translate into a 2.3 amp draw if it were drawing constantly, which it would not be doing because presumably it would cycle such that it averaged out to that number, but you can readily see the difference in efficiency.
Perhaps I'm not yet fully awake this morning, but I cannot find where the Whynter states its energy requirements. The Whynter Elite 45 Slim Fit looks promising and I even looked at the user manual, but I cannot find that vital piece of information, so it's difficult to compare.
