Old 02-03-2019, 11:17 AM   #1
Reidsville , North Carolina
Wiring Refridgerator
I have purchased a used RV Refrigerator that is gas/ electric. Our camper had a residential fridge. Due to the type of camping we are doing, we really want the ability to use the fridge on gas. This new refrigerator is a typical RV Dometic refrigerator. I don't think the original frdige from my '78 Excella 500 had a 12 volt connection. I need to add a 12 volt connection for the fridge to work. I'm thinking I'll run wiring either directly from the batter with an inline fuse or from the panel box. Not sure yet. suggestions welcome.
I would like to know suggestions on what gauge wiring I should use and what size inline fuse would be best?
kn4jpd is offline   Reply With Quote
Old 02-03-2019, 11:58 AM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
There will be a 12v wire in your compartment behind the access door for the fridge. All of the fridges use 12v for their controls. Look for a wire that is taped off and check with a meter for power. It will come from your 12v distribution panel and will be fused. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 02-03-2019, 12:30 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Actually, the earlier fridges did not have a 12 volt control board. My 1975 did not have one. I would look for the nearest 12 volt line and tap off of that. The control board in the newer fridges do not pull much power. In my 75 there was a TV connection and plug above the fridge. That would have been my power if I had replaced the fridge.
Richard
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 12:08 PM
Need a New Refridgerator Vent Cover John and Anne Airstream Motorhome Forums 3 07-11-2004 07:41 AM
Refridgerator was working Just Fine,...til I started messing with it MileHigh Refrigerators 2 06-12-2004 12:56 PM
1969 Sovereign Refridgerator Door jyobp Refrigerators 1 01-25-2004 05:40 PM
Refridgerator Removal DRLee Refrigerators 17 10-10-2002 12:38 PM
