Old 09-29-2020, 07:24 PM   #1
2015 27' Flying Cloud
COLLEGE GROVE , TN
Water pooling in the bottom of 27fb 2015 Flying Cloud refrigerator...
Our 2015 FC Dometic fridge has begun pooling water in the bottom under the fresh food boxes at times and wonder if anyone has had this problem. What is causing that and how can we fix it? Thanks for any advice.
mnicholson65 is offline   Reply With Quote
Old 09-29-2020, 08:33 PM   #2
Rammonte's Avatar
2020 16' Nest
St. Catharines , California
Is that a 3-way fridge? I havenít
experienced this problem in an airstream fridge but my spare basement 125v fridge did. It turned out to be a condensation drain line clog. Likely caused by ice. I unplugged/ turned off the fridge for 24hrs and then ran a section of copper wire up the condensation drain line. You may be able to fix the problem by allowing the fridge to fully defrost. Is there an access to the rear of your fridge?
Rammonte is offline   Reply With Quote
Old 09-29-2020, 11:10 PM   #3
Newport Beach , California
Mine does the same thing! I would love to know this too. I keep a shamwow under the trays, wring it out before I travel, and wash it when I do wash. For now it works as a temp fix but I would rather just get it fixed.
reginac is offline   Reply With Quote
Old 09-30-2020, 05:19 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I bet the cooling fins are dripping water like it should into the tray but the drain or hose is blocked and not dripping out like it should.
Open the fridge door on outside, see that hose that comes off of fridge and goes thru the floor to drip the water outside like it should.
Look for debris in the bottom of the drip tray and roll up your sleeves.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-30-2020, 12:30 PM   #5
2015 25' Flying Cloud
2006 19' Safari SE
Portland , Oregon
I had the same problem in my 25’ Flying Cloud. I found that the outlet nipple on the drip tray was not long/deep enough to carry the water far enough into the drain tube. so it was back flowing and dripping down the back of the fridge and puddling at the bottom under the draws. So I added a few inches of clear tubing onto the drain tray nipple to carry the water farther into the drain tube. And it worked. No more puddles.
KellyRice is offline   Reply With Quote
Old 09-30-2020, 01:22 PM   #6
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Great Idea!
Originally Posted by KellyRice View Post
I had the same problem in my 25í Flying Cloud. I found that the outlet nipple on the drip tray was not long/deep enough to carry the water far enough into the drain tube. so it was back flowing and dripping down the back of the fridge and puddling at the bottom under the draws. So I added a few inches of clear tubing onto the drain tray nipple to carry the water farther into the drain tube. And it worked. No more puddles.
Nice fix! Thank you!
Mikebrady62 is offline   Reply With Quote
Old 10-10-2020, 10:37 PM   #7
After you posted this I checked my leaky fridge and that is the problem with mine too! I swear I heard angels sing when I read your response to the post. Yes! A good fix! THANK YOU!
Water pooling lower window frame TCTradewind Windows, Doors, Locks & Vents 3 03-23-2015 10:21 AM
2015 27FB vs 28 Flying Cloud Pat Cassity 2009-2015 Flying Cloud 0 10-17-2014 11:29 AM
Shower Door Bottom Seal replacement for 2012 27FB jasperkins Sinks, Showers & Toilets 3 10-27-2013 09:24 AM
Water pooling in bath sink altamont Sinks, Showers & Toilets 12 10-16-2007 08:02 AM
