Old 03-31-2023, 04:25 PM   #1
Spencer , New York
Vintage Dometic gas only refridge
I have a 1961 Overlander with an original dometic lp gas refrigerstor. I've had it for about 15 years and the fridge has worked pretty well. Had one episode about 5 years ago where the flame was wonky and we had some trouble keeping it lit. I recall that I somehow, but don't member how, I cleaned the burner an it's worked well since. I am currently about 500 miles from home and it is misbehaving. The flame isn't quite right and there appear to be some deposits in the rim of the burner that throw off a bit of Orange into the flame. I can live without it for the 2 weeks of this trip and have a lot of patience with relighting it. But, I would rather get it back on track with out making a bad situation worse. I love this fridge and want to keep it working. Any vintage enthusiasts out there with some advice? Thanks in advance for your consideration. Mark
mbaustian is offline   Reply With Quote
Old 03-31-2023, 08:22 PM   #2
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Leon and National RV Refrigeration has done modern retrofits on 60's refrigerators for many of us in the vintage trailer world where we want to maintain the look of the original but have it work. He takes a modern cooling unit, builds whatever he needs to make it work, welds it all together, recharges the unit. Typically he can build it so you have modern electronic ignition, plus 110 option, and all you have to do is find a cabinet or somewhere to mount the small push button control panel. They typically do those builds in the winter, but take reservations for the work. Not a project you can be in a hurry for, but very much worth the wait!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-31-2023, 09:58 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Lots of good videos on You Tube about cleaning the burners on these older fridges. Find one that's close to how your model looks and have at it. I cleaned mine in an hour or so and the flame was great afterwards.
Cleaning a propane fridge's burner and chimney tube are part of the routine maintenance, and it sounds like yours is a bit overdue.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 04-17-2023, 06:06 AM   #4
Spencer , New York
Thanks for the good tips - update
We've returned from our trip and am happy to report that the dometic settled down and worked well for the remainder of the trip. Good to have the info about the re-builder as someday this old pals number will come up - gladly that day is not today. Also thanks for the PM reminder. I give myself a D on pm. Not that I am not able or don't understand the importance but I do fear converting something that works into something that doesn't. Time to get over it. Thanks again
electric only refridge pearl66 Refrigerators 24 05-30-2010 07:29 AM
Refridge in 72 Tradewind won't cool RichHog Refrigerators 14 03-01-2009 07:22 PM
RM 3807 Refridge-I-hate-ya dalefox Refrigerators 3 08-05-2008 12:13 AM
Refridge light not working, Well it works too good ??? myfirstrv Refrigerators 5 05-07-2008 02:24 PM
recommendation for Refridge Tech DKinsey Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-23-2005 07:51 AM
