Old 06-13-2021, 09:31 PM   #1
2021 20' Caravel
Ventura , California
Turning NovaCool AC DC refrigerator the night before
I’m a new owner of a 2021 Caravel with factory solar package (AMG batteries - 90 watt solar). Looking for opinions on whether I should be able to turn my electric refrigerator (12 volt) on the evening before departure without risking draining my batteries. I have offsite storage and no access to shore power.
Gerdog is offline   Reply With Quote
Old 06-13-2021, 09:48 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Our 3.1cf Novacool uses 3.15 amps (41 watts) and runs much more than it cycles off. I figure it uses at 50-70 amps in a 24 hour period. Since during the day you'll most likely have solar input or be driving, it should be very manageable if your batteries are performing as intended.
Your fridge will cool quickly and since you do not have power where it is stored, I think you'll be ok to turn it on a few hours before you leave, and then be sure to load it with pre-chilled items from your home fridge.
You may still need a day or two to adjust the temperature to get it just right. I usually start mine on setting 5 or 6 (out of 7) and then adjust it down if it gets a bit too cold. However, we travel in mild temps. So the heat this time of year will have some effect. Use a good thermometer inside the fridge to monitor once a day.
rowiebowie is offline   Reply With Quote
Old 06-14-2021, 04:43 AM   #3
Sag Harbor , New York
A simple trick . . . Have big blocks of blue ice frozen at home, and put them in the fridge when you leave. New cold thermal mass will chill the fridge in 5-10 minutes without electricity.
Problem solved!
KISS
Also never put warm stuff in. Pre-chill in ice cooler in tow vehicle.
KISS
Happy trails,
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 06-14-2021, 09:38 PM   #4
2021 20' Caravel
Thanks for the information very helpful and confirms that we will need to turn on the power to the fridge the day of. Appreciate the suggestions for keeping our food cold!!
Old 06-15-2021, 12:50 AM   #5
Cool
Welcome . . . we 20'-footers need to chill out together . . .
The best galley in the Airstream line, until you get up to 27' or so IMO.
Peter
Old 06-15-2021, 11:55 AM   #6
bcheever's Avatar
2021 22' Caravel
SEATTLE , WA
We have a new 22FB Caravel with similar issues.
We bought this thermometer for inside the fridge:
https://www.amazon.com/dp/B07RN7Z2RT...p_mob_ap_share
And use blue ice and pre chill everything going in as others have mentioned.
Also:
We lock the fridge and turn it off over night (save power but also the sound keeps my wife up)
Eat the most perishable stuff early in the trip and use a small cooler bag for drinks so kids aren't opening and shutting the fridge unnecessarily.
When I was a kid my parents had a trailer that just had ice blocks in it, no power at all, so I figure this is a big step up from that :-)
It's manageable, good luck!
bcheever is offline   Reply With Quote
Old 06-15-2021, 03:42 PM   #7
2021 20' Caravel
Agreed!!!!
One night in a two-night minimum campground? dlfphoto On The Road... 21 08-05-2020 06:57 PM
Two night shake down before leaving for an extended trip reelfastgreg On The Road... 10 03-06-2015 06:37 PM
Turning off refrigerator before fueling TV kswelsh Refrigerators 29 11-14-2013 05:35 PM
Heater turning to cold air in middle of night zenarmy Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-04-2012 10:49 PM
T'was the night before Christmas when all through the house SmokelessJoe Off Topic Forum 3 12-24-2006 09:28 PM
