Old 10-30-2017, 09:59 AM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
simple electrical fix? '72 Dometic fridge
hi folks, just wondering if there's a short list of simple things to check on these older fridges. It works on LP, just ..keeps the interior at 39 quite easily if trailer is in shade most of the day or not too hot. Last trip in Nevada City, it was close to 95 most days but were shaded. But can't get this fridge to run on electricity. Would some tips on troubleshooting. Thanks
nickclifford is offline   Reply With Quote
Old 01-10-2019, 03:35 PM   #2
1974 27' Overlander
San Francisco , California
From my recent experience, it's likely your heating element. I've got a 72 Overlander with the Dometic RM77 which had the same problem. You can test if your element is getting power (should be 110vac) by testing for AC power between the two wires going to the heating element. If you see 110vac, going to the element when the fridge is on, replace the element. You can access the element by sliding the metal cover (about 1.5 inches wide by 5 inches long above the burner) up and out of the way. move some of the insulation around until you find the top of the metal element. It's got two wires sticking out of the top of it. there's a small metal clip you need to push back and away, then simply slide the element out. The element is a 4 inch? long metal tube. Cut or unplug the wires outside of the heater box and replace it with a new one.
I did this and boom! Electric fridge functionality.
-Greg
Creech is offline   Reply With Quote
Dometic Fridge in '68 Overlander - easy to fix? _ally Refrigerators 0 05-24-2016 07:54 AM
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 03:23 PM
Simple electrical question about Batt. and charger jasoncase Electrical - Systems, Generators, Batteries & Solar 7 07-18-2009 09:25 AM
Simple Electrical Hookup Questions mcipriano Electrical - Systems, Generators, Batteries & Solar 11 06-26-2009 02:57 PM
