Old 05-12-2021, 04:46 PM   #21
G-Ranch
G-Ranch's Avatar
1970 25' Tradewind
Smyrna , Georgia
Roof vent
Originally Posted by JCWDCW View Post
The fan if fitted on a trailer will always run on a hot day ( 75+ degrees ), it doesn’t move a lot of air but keeps it moving over the condenser coils
Makes a difference on our 2014 Bambi with side vents. Never seemed to need it on my 96 Excella even in 105 deg weather in Doswell Va
JCW
Finishing the renovation of a 1970 Tradewind. The “original design” frig vent included a 9” x 9” hole in plywood floor below the frig. The roof vent w rain cap is approximately 4” x 14”. Clear path for air flow was definitely provided.
Installed a Dometic 7 cubic foot frig with fan (thermostat control). Fan runs a lot. Either 110 volt or gas operated - outside Temperature above 75 degrees will trigger the fan. I Thought the chimney effect would be more than adequate. Maybe the larger refrigerator is a part of the equation. Was hoping advancement in 50 years evolution of refrigeration technology would have helped.
G-Ranch is offline   Reply With Quote
Old 05-12-2021, 05:50 PM   #22
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Second Fan
Airstream factory service on our 2019 25 pulled the refrigerator out installed a second fan up top to help pull the heat up. Make sure you have it switched so you can turn it on or off off. Not needed under 80 degrees and low humidity
Originally Posted by ETroup View Post
The aluminum rain cap is riveted on and extensively sealed. Will be a bit of a job to remove and replace.
Life is a Highway is offline   Reply With Quote
Old 05-12-2021, 06:18 PM   #23
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , PA
Haven’t had time to pull my refer out and install a fan up high to increase air flow out the top. On the 2021 project list…. Had a pretty powerful 12 v fan laying around in the garage though, so I quickly installed it in the lower compartment blowing upwards. Noticeable difference in cooling—setting can be set at least 1 number lower. Not totally scientific but climbed up and placed my hand near the vent and definitely feel more exhaust flow.
VeloBuckeye
2018 Flying Cloud 27FB - "The Shoe"
VeloBuckeye is offline   Reply With Quote
Old 05-13-2021, 08:27 PM   #24
2002 34' Classic S/O
sault sainte marie , Michigan
Originally Posted by guskmg View Post
As stated, make sure the draft path behind the cabinet is completely clear of obstacles. My refer did not come with a fan, but I added two, it makes big difference on overall cooling and efficiency. The computer fans use very little DC power.
guskmg
Amen, computer fans very inexpensive, the bigger the better. I had to have the cooling unit on the back of my fridge replaced/rebuilt and the tech who did it onsite where I was staying told me to put the fans at the top of the fridge vent flue (next to the center A/C). I wired a basic switch into the 12V DC fridge connection for the fans and fed a wire to supply power to the fans and attached the fans to the screen at the top after drilling out the rivets and reattached the rain cap with sheet metal screws and bit of sealant. PHX gets very warm and fridge operation is improved for not much $$.
bartzstream2 is offline   Reply With Quote
Old 05-28-2021, 06:20 PM   #25
3rd RV, First Airstream
ETroup's Avatar
2021 27' International
Orlando , Florida
Send a message via Skype™ to ETroup
Refrigerator vent and heat dissipation
Thanks everyone for input. I have fabricated a metal bracket / shroud to hold two 120 mm computer fans with a simple on / off toggle. Here is a picture of the complete assembly ready for installation. Click image for larger version
Name:	Tire Load vs Pressure Analysis Airstream 27FB.jpg
ETroup is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Expectations from the AC and refrigerator, and coping with excessive heat UKDUDE Sprinter and B-van Forum 15 08-05-2015 12:22 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
