12-02-2022, 06:27 PM
2018 27' International
San Antonio
Refrigerator Replacement
I have purchased a 2018 International Signature 27FB. The Dometic RM3762 refrigerator installed has a coolant leak and I have decided to replace it with a 12V unit. The only two direct size replacements are the Dometic DMC4081 and the Norcold N8DC (apparently the one that Airstream installs in its new trailers). I have read all the pros and cons of a 12V refrigerator and decided to proceed anyway. What I would like to know is which model has the best record and if there are any pitfalls connected with this project.
Any input is welcome....I am new to the Airstream family.
12-02-2022, 07:38 PM
2017 25' International
West Lake Hills
I realize that you’ve already decided to go with the 12v fridge. So maybe this is old info for you that you’ve already considered.
The guts of the fridge are replaceable without having to replace the entire. Unit. Lots of threads here regarding how to do it.
12-02-2022, 08:39 PM
1977 31' Excella 500
West Sacramento
I would go with the Norcold as Dometic nowadays has a reputation for discontinuing units accross their product line after only a couple years with no repair parts available.
12-03-2022, 10:18 AM
2016 22' Sport
WALNUT CREEK
We replaced our unreliable 3-way Dometic with a 12V DC only NovaKool refrigerator. I was unwilling to use Dometic for the reason noted by 4RXLA, and NovaKool seemed to have better reviews/reputation than Norcold. That was about a year ago and no complaints so far.
12-03-2022, 11:15 AM
1994 25' Excella
Waukesha
, Wisconsin
You can also check out Vitrifrigo. They make a great product and might have one to fit your needs. We had one in our coach and thought the quality was far better than either Dometic or Norcold units we compared it to.
Richard
11018
12-03-2022, 12:45 PM
Naples
Howdy,
Vitrifrigo is the only fridge unit that we install into Airstreams. They work extremely well and probably have a unit to it your needs.
lewster
12-03-2022, 01:08 PM
West Sacramento
I wanted a Vitrifrigo but couldn’t get one timely. I was lucky to get a NovaKool with only a 2 week wait. I’ve been happy with the NovaKool so far. Mine is dual AC/DC.
12-03-2022, 01:53 PM
San Antonio
Where to purchase?
Originally Posted by lewster
Howdy,
I would love to look into this brand if I could find a source!
12-03-2022, 04:43 PM
Williamsport
Vitrifrigo fit perfectly. Fridge consumes very little DC power once cold. Check out online boating/yacht sites...found the best, delivered deal that way. Attachment 425944
12-03-2022, 05:16 PM
San Antonio
Ac/dc
Do you connect it to either 12v or 110V or both and then there a switch to select which power source to use?
12-03-2022, 05:25 PM
Williamsport
It is a 12vdc compressor. The fridge does have a 110v plug and 12vdc connection. We run it off the 12 vdc connection and don't have the 110v plugged in.
There is no switch. If you're plugged in or inverting it will run off 110v, otherwise 12vdc.
12-03-2022, 06:14 PM
West Sacramento
FYI the NovaKool RFU9000 has the same power set up and mine is plugged in to 120V. It automatically switches over to DC and I have no battery drain while towing. I have 2 Lifeline 100 amp/hr AGM batteries and the fridge can run up to 4 days on the batteries before the low power auto shut off kicks in. No solar.
I rarely boondock and have a generator so the DC operation doesn’t concern me. I bought mine from a marine store in San Diego. Vitrifrigos were backordered at the time and I got the 2nd to last NovaKool unit that was on order from Canada.
Hopefully supply chains are better now than in the spring.
12-03-2022, 08:31 PM
1994 25' Excella
Waukesha
, Wisconsin
Here's where we got our Vitrifrigo.
https://www.suremarineservice.com/Galley/Refrigeration/
They have a distribution center/main office in Florida, but all sales go through a dealer. I found Sure Marine to be great to work with. The one time we had a problem the folks at the distribution center/main office helped us and sent parts on the road.
They all can be connected to both 12vdc and 120vac. We didn't bother plugging into 120vac either. Leaving it on 12vdc made for a simple/easy install and freed up an outlet to use for other things. When you're not plugged in you need it on 12vdc anyway, and when you are plugged in the converter/charger can easily absorb the small load and still have enough to charge your batteries.
Richard
11018
12-04-2022, 05:51 PM
San Antonio
DC wiring
Does anyone know if there is a chase under the floor between the DC power panel and the back of the refrigerator? I ask because I will be increasing the wiring size for the DC refrigerator from the panel to the power connection on the back of the refrigerator and was wondering how difficult a fish that is?
12-04-2022, 07:23 PM
Williamsport
There is a chase. If you open the 2 cabinet doors under the closet and access the area where the water pump is you will find it. It goes across to the area behind the power panel. Very easy to fish wires...it has several bundled wires running through it for reference that are easy to see.
11-23-2023, 06:23 AM
Owner of 2 Airstreams
2014 16' Sport
2017 27' Flying Cloud
California
, MD
Originally Posted by HienzExum438
What is the model # of the Vitrifrigo refrigerator you installed?
Thank you.
11-24-2023, 07:55 AM
San Antonio
I installed the DP2600IXD4-F-1. I direct wired it to the DC panel with a 10ga wire. It comes with a converter which you can use to hook it to the AC plug already installed but that would mean you have to have shore power or inverter powered up before it would run...didn't want that. Took it camping in the worst of the Texas heat last summer and it kept my ice cream frozen just fine.
