Old 04-15-2017, 06:23 PM   #1
2016 16' Sport
Charlotte , Iowa
Refrigerator fan running continuously
I have model RM2351 refrigerator in my 2016 Sport. When in propane mode the fridge fan runs continuously (never shuts off). When in electric mode it runs intermittently. Is this normal? Thanks
Bill
boocanoe is offline   Reply With Quote
Old 04-15-2017, 06:28 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have found that by keeping the fridge side in some shade, and propping open the fridge vent hatch(s) the fan very rarely runs. We also replaced the noisy original with a computer-style fan so when it runs, we never hear it.
Doug and Cheryl
Old 04-15-2017, 06:45 PM   #3
2014 16' Sport
Route 66 , Arizona
Bill
Yeah it's kinda sorta normal. Ours never shuts off regardless of whether it's on propane or electric. What's normal is this: It's annoying! That's why so many have replaced the fan with a quieter one. There's an extensive thread on that very topic but I'm too lazy to find and provide the link to it.
Skooter is offline   Reply With Quote
Old 04-15-2017, 07:20 PM   #4
interstateflyer's Avatar
2017 25' International
Los Osos , California
Have a on/off switch installed. Airstream had my dealer mount a lighted red rocker switch on an interior wall. It allowed us to turn it off at night and when we wanted quiet time.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-16-2017, 06:20 AM   #5
Sag Harbor , New York
Echoing earlier comments. We turn ours off at night, and prop open the upper exterior louvered ventilation door when possible.
Old 04-16-2017, 08:01 AM   #6
2016 19' Flying Cloud
My 2016 FC 19 came with an on/off switch for the refer fan so I was surprised to learn that some don't. And I've never heard the fan even though I always leave the switch on. Now I guess I should check and see if the fan is broken.
ATownTX is offline   Reply With Quote
Old 04-16-2017, 08:08 AM   #7
You might want to check out this thread:
http://www.airforums.com/forums/f542...on-165390.html
for other possibilities like inline fuse out, etc..
Cheers,
Peter
Old 04-16-2017, 08:39 AM   #8
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
ARP Module
You might want to look into the ARP module. see https://www.arprv.com/
I had one installed on my Excella (without the fan - version 2; the fan model is version 3) after meeting Paul and Mao at the Escapade in Tucson last month.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 04-16-2017, 12:38 PM   #9
2019 25' Flying Cloud
Sequim , Washington
I plan to replace ours with one of the quieter pc fans. In the meantime, in addition to the other tips in this thread, I installed a 1/2" wide strip of closed cell foam (camping mat blue pad type stuff) between the fan and the metal frame. This is the "before" photo, but I cannot find the " after" photo at the moment. But you get the picture. This no-cost 30-minute job reduced the noise considerably.
Because ventilation is important to the mechanics and cooling system, I would be wary of turning the fan off or disconnecting it.
WestieHouse is offline   Reply With Quote
Old 04-16-2017, 08:44 PM   #10
CruizinDux's Avatar
Washington , Missouri
Bill
boocanoe, the refer will run hotter on propane vs AC and as such the fan will run more often/longer.
Probably N/A but you might also check the stat button on the fins
http://www.airforums.com/forums/f382/refrigerator-fan-157385.html#post1856439
Like Peter I always prop up the top opening and it usually turns off in a few minutes. New fan = quiet, almost not even noticeable. Best $20 bucks I ever spent on the TT. I never have to turn the fan off.
Here is the mother of all threads re a LOT of different TT's and various fan/sheet metal engineering solutions.
http://www.airforums.com/forums/f425...-11811-19.html
Just swap out the fan. Don't over think it, especially the need for sheet metal IMO for your unit. Older TT's with different designs obviously have benefited.
here are my posts re refer fan on 20-footers thread
pre-install comments: #688
http://www.airforums.com/forums/f516/20-footers-127845-50.html
install comments: #711
http://www.airforums.com/forums/f516/20-footers-127845-51.html#post1774433
Post install comments: post #836
http://www.airforums.com/forums/f516/20-footers-127845-60.html#post1785587
Lastly the engineering from SilverGate re opening the upper door
Original suggestion of opening the top refer door: post 11
http://www.airforums.com/forums/f425/noisy-refrigerator-cooling-fan-151523.html
CruizinDux is offline   Reply With Quote
Old 04-17-2017, 09:57 AM   #11
2004 22' Safari
Albuquerque , New Mexico
I bought a computer grade fan from Egghead for $11 (yellow blade) and I only needed a few spacers since the hole separation distance was the same, but the new fan was thinner. It also moves more air for less energy. It is almost dead silent. When it runs I can't hear it, and now I have to check occasionally to make sure it is still running. Nice at night though.
Silver.Sanctuary is offline   Reply With Quote
Old 04-18-2017, 11:34 AM   #12
2015 25' Flying Cloud
Tappahannock , Virginia
Yes this was the most annoying over night issue with our new FC25 so I replaced the grounchy bearing Rodale with two side by side very quiet computer fans that suck the air out and also made an aluminum shaped air shroud to draw air through the fins... see photo at
https://www.facebook.com/AirstreamTw...344935081354:0
David & Margaret Broad
2015 25 Flying Cloud
2015 RAM 2500 Laramie Cummins
WBCCI # 2381
RivaHaven is offline   Reply With Quote
Old 04-19-2017, 04:29 PM   #13
2014 23' Flying Cloud
Rhinebeck , New York
Same issue with our 2014 23D International Serenity. I never understood why the refrigerator fan ran constantly. We weren't camping enough for the matter to get me in the "I gotta figure this issue out." We traded the 2014 unit for a 2016 16' Sport for camping convenience issues such as using small state campgrounds for example. Don't recall fan issues with the new Sport but we'll find out soon. Not sure I'd like turning off a fan with a on/off switch as I'd figure "it" was running because it was required. No problem opening outside access point however. Love advice always.
Adam Geuss is offline   Reply With Quote
Old 09-24-2021, 01:29 PM   #14
Sedro Woolley , Washington
Can you please give me the part number or the name or a link to the computer fan you installed to quiet dometic fan. It is driving us crazy in our new 2020 AS flying cloud runs all the time
SMScott is offline   Reply With Quote
Old 09-24-2021, 07:24 PM   #15
DougnJanet's Avatar
2013 23' FB Flying Cloud
Kennewick , Washington
SilenX Effizio Silent 120mm Thermistor Edition fan
Details
Product Dimensions‎
4.72 x 4.72 x 0.98 inches
Item Weight‎ 6.4 ounces
Manufacturer‎ SilenX
ASIN‎ B005Z1QJW2
Item model number‎ EFX-12-15T
Installed this in place of factory fan in 2015 and it is still running silent
Doug
DougnJanet is offline   Reply With Quote
Old 09-25-2021, 12:12 AM   #16
2004 22' Safari
I spent a lot of time looking for the Amazon order but apparently I did not get the fan(s) from Amazon. Maybe I got them from Egghead... since they were computer fans made by SilenX as the poster suggested, Mine were yellow and I store the trailer about 10 miles away but am headed that way soon. My unit is a 2004 Safari and perhaps Airstream is using something different, but the fan(s) I bought had the same exact mounting holes and all I had to do was take the old one out and put the new one in. I used the original mounting. Since they were fairly cheap, I had purchased two and had the second for a long time before I finally installed it to increase the air flow. These were so much better that I can't hear them when they do go on and use far less energy than the junk that Airstream put in.
Get the dimensions, but the other poster probably has the right data.
Old 09-25-2021, 05:22 AM   #17
Silent fans
I bought two of these:
https://www.amazon.com/gp/product/B000OZ7YEG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1&fbclid= IwAR16kd6F5XWFj_s3Bmoi2TQiVkXb2km_mInucqeHEKQqxz7a AlX_kkxcQgg
Here is the description of the install:
https://www.facebook.com/AirstreamTweaks/photos/a.1083338771748637/1083344935081354/?type=3
We also made some improvements see:
https://www.facebook.com/1083330468416134/posts/3614090902006732/?d=n
Feel free to ask any questions!
Inverter runs continuously???? mwilliamsmd Electronics & Connectivity 20 11-01-2016 10:41 PM
Refrigerator fan switch or fan dugan Lights - Interior & Exterior 4 09-16-2016 02:59 PM
AC/heat pump runs continuously unless shut off manually lsinclair Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-13-2010 07:47 PM
Water Pump Runs Continuously craftsman Water Heaters, Filters & Pumps 6 12-01-2009 11:38 AM
Refrigerator Fan won't stop running tsunami Refrigerators 18 09-17-2007 01:50 PM
