Old 04-10-2019, 11:16 PM   #1
my3sonsdad's Avatar
Vienna , VIRGINIA
Refrigerator circuit
I was attempting to install a mortise cylinder lock and in the process managed to short circuit my front area 12v lighting. The only wires nearby are the flood light & and over head door light. Whatís odd was the refrigerator stopped working too.
It was really late so I didnít go through the checks to see if one or more fuses got blown, but Iím curious why the refrigerator circuit would get tripped?
2001 Ford Excursion 7.3L
my3sonsdad is offline   Reply With Quote
Old 04-10-2019, 11:25 PM   #2
2007 22' International CCD
Might be on the same fuse. Not unusual.
Old 04-12-2019, 06:41 PM   #3
my3sonsdad's Avatar
Vienna , VIRGINIA
That was it! ... but wasnít obvious. I replaced the obvious blown 20A fuse (at the top of my fuse stack) but that wasnít it. Then I decided to start down the stack replacing fuses. Fortunately it was the 2nd fuse.
Must have tapped the back of the flood light switch & the overhead door switch.
Old 04-12-2019, 06:56 PM   #4
The joys of working with electrical stuff inside a tin can...
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
vintage brake circuit wildcat455 Axles 8 08-04-2003 09:04 PM
Circuit Breaker Happycampers Electrical - Systems, Generators, Batteries & Solar 4 07-26-2003 06:51 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:25 PM
