Old 11-25-2022, 02:37 PM   #1
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Refrigerator
Thermistor replacement
Hi. My Dometic refrigerator suddenly started freezing everything in the refrigerator section. Upon searching the internet it seems a bad thermistor was probably the culprit. I never had the plastic thermistor clip, so in the past I used a binder clip. After researching parts I ended up purchasing this kit which included a thermistor, clip, and grommet for the back of the frig. Amazon, DOMETIC 3851210025 Thermistor Kit, ( https://a.co/d/7VXYvJK ). My old thermistor was smaller and black, But the refrigerator model and thermistor part search informed me that the new thermistor was correct. Initially I was planning on pulling the new thermistor from the frig into the control section outside. But it was obvious the control board connector was to big to go thru the hole in the back of the frig. So I ended up cutting the connector of the old thermistor wire and taped the new thermistor securely to the old wire. I pulled the wire from inside the frig. Pulling was a bit difficult, at times I was afraid I might break the wire, it appears the old wire was glued somehow to the back of the frig. Ultimately I safely succeeded. The new grommet in the kit was welcome as the wire hole was slightly different. In my internet searches, it seems the thermistor’s are not very secure in the plastic clip’s, and the solution is a small hole with a small panduit, so I did the same. 1-day later and refrigerator temps are where they are supposed to be, Hooray!
Happy Thanksgiving to all!
& God Bless!
ID:	425723   Click image for larger version
ID:	425725   Click image for larger version
ID:	425727   Click image for larger version
ID:	425729   Click image for larger version
ID:	425731   Click image for larger version
ID:	425733   Click image for larger version
ID:	425735   Click image for larger version
Ahroc is offline   Reply With Quote
Old 11-25-2022, 07:20 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Very good diagnosis, parts search, and install. Working on these refrigerators without removing them is a bear in my view. I've spent many hours on my 5 year old RM 2510 five cu ft fridge. The dang fuel selector switch fell apart and wouldn't deliver 12v to the igniter module. I finally got the thing running.
It is my view the Dometic RM 2510 fridge is not well designed or manufactured. It is difficult to work on. But what do I know. Mine is a bottom control and all manual operation.
You done good.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 11-25-2022, 11:30 PM   #3
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Hi dbj216
Thanks for the note!
Frig model if anyone is curious.
Dometic, RM2652, 921 14 40-61
This became a priority project because its really hard to drink frozen beer :/.
Happy Travles!
Old 11-26-2022, 10:35 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
When placing the thermistor, remember that up (closer to the freezer) is for a warmer refrigerator; lower (farther from the freezer) will make the refer cooler.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Refrigerator Fan Running when Refrigerator Off DCPAS Refrigerators 9 09-13-2020 01:47 PM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 02:30 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 09:07 PM
Flame out on Refrigerator When Traveling jcanavera 2000 - 2004 Safari 8 12-07-2002 11:44 AM
refrigerator panels eraffety Airstream Motorhome Forums 2 04-01-2002 12:20 AM
