Old 07-16-2021, 07:49 AM   #1
2016 27' Flying Cloud
Fresno , California
Refer works on propane only
I recently had my AS, 2016 27 FB in Mexico, plugged in to shore power, the circuit breaker tripped and when reset, by others, sent low voltage to the trailer. It burned up my inverter which I replaced and is working fine but the fridge will now only work in propane mode. I replaced the controller but still works only in propane mode. The fridge is a dometic RM3762RBX. Appreciate any advice on how to get it working in both modes.
Penasco Pete is offline   Reply With Quote
Old 07-16-2021, 08:42 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you check the electric heating element resistance?
It plugs into the controller. Disconnect AC power, unplug and check resistance of the heating element.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 07-16-2021, 08:52 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I would suggest that an EMS would be a good thing to get. They cost a lot less than replacing a bunch of stuff in the trailer .....
Old 07-16-2021, 05:15 PM   #4
Fresno , California
Thank you very much for the info, I see where someone else had this problem, you responded, but they were unfamiliar with using a multimeter. I'm going to go out and give it a try, next challenge will be finding a heating element for the RM3762RBX, my research shows they're discontinued. Thanks again for the info
Old 07-16-2021, 05:52 PM   #5
GCinSC2's Avatar
Test first then make decision.
Getting a resistance reading in range for the element no need to replace. Gettin an open circuit nobody’s home reading now replace.
Many online tutorials and meters have instructions.
Want to test drive first, borrow a friends and use their experience.
Also Dometic does publish specs for element just have to pin it down in document.
S/OS #001
Old 07-17-2021, 09:40 AM   #6
2010 25' FB Flying Cloud
Snoqualmie , Washington
Had similar problem about a month ago. Had to just keep turning the mode switch back and forth and also turning fridge on and off. Not sure which one made it finally go - but took hours (usually waited a while between cycles to determine if it was on). No problem since then. Good luck.
Anders79 is offline   Reply With Quote
Old 07-17-2021, 01:58 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
First the electrical fix-all: Turn off (unplug) all electrical devices. Wait 10 seconds and reconnect. Open and close all circuit breakers and fuses.
Now, repower up all electrical equipment. Turn on and set the refer mode switch to electric. After a few minutes, if the burner chamber does not feel hot on the side you need a new 120v element. They are not very expensive and are available at most any RV parts store. Be sure and check all AC and DC equipment for operation after a power fault. If it was on when the power interrupted you probably damaged it.
guskmg
Old 07-17-2021, 02:51 PM   #8
2018 27' Flying Cloud
Delray Beach , Florida
At the risk of sounding stupid (me, not you) did you try the glass fuse outside, behind the refrigerator?Don’t ask me how I know😠
Lew
2018 27' Flying Cloud 2018
Ram 2500 Cummins, ProPride
#4636 FL/NC
South Florida Airstream Club #30
time2travel is offline   Reply With Quote
Old 07-19-2021, 02:57 PM   #9
Fresno , California
I ordered the heating element on Amazon, received it Sunday, installed it the same day, refer is working perfect again. I will get a surge protector and will always check on air forums before randomly replacing parts. Thank you so much GCinSC2, you nailed it.
Old 07-19-2021, 03:20 PM   #10
GCinSC2's Avatar
Pete
A bit of luck. Glad fridge is working. Curious any obvious oh wow look at that regarding old element?
Congrats
Gary
S/OS #001
Old 07-19-2021, 03:33 PM   #11
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
@Penasco Pete
This Diagnostic Service Manual from Dometic may be helpful next time your refrigerator acts up:
http://www.nancyemmert.com/region6/R...atorManual.pdf
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-20-2021, 07:21 PM   #12
Fresno , California
Hi Gary,
There were no outward signs of any problem with the malfunctioning heating element, I tested the new one and the old one and got a reading on the new one, no reading on the old one. Thanks again for the help, Pete
1972 Dometic Refer Works on Electric, NOT Propane? shirlgirl Refrigerators 11 08-06-2020 11:12 AM
Argosy refrigerator only works with propane Kartimel Airstream Classifieds 0 03-02-2016 03:59 PM
Dometic 2801 refer works backwards?! cjack99 Refrigerators 3 09-28-2012 04:16 PM
New electric jack only works occasionally Zmod Jacks, Stabilizers, Lifting and Leveling 3 06-14-2004 08:09 PM
my DC works only sometimes Tomcat Electrical - Systems, Generators, Batteries & Solar 2 04-27-2003 11:26 AM
