Old 07-03-2009, 09:43 PM   #1
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Propane leak in Dometic 660 refer
My '68 Safari's Dometic refer fills the cabin with gas odor when it's on propane. The leak must be after the rotating valve that you access through the side panel to turn on the gas, since the smell goes away when I close that valve and use AC to run the refer (which doesn't do much of anything in the current 102 F Texas heat). I can't find the leak with bubbly soap. There is no yellow in the flame--it runs loud and blue. Where could the leak be, and how can I fix it?
26.982 amu is offline   Reply With Quote
Old 07-04-2009, 02:18 PM   #2
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Oops, that's Dometic RM60--sorry.
Old 07-04-2009, 02:54 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Did you spray the whole hose and connections with soap and water?
Try down under the trailer where it comes through the floor. Gas does rise.
Can you smell it under the trailer at all?
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline   Reply With Quote
Old 07-05-2009, 04:06 PM   #4
1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Today I went over the propane line leading to the burner with an eyedropper loaded with soap solution--finally found the leaks (several). They are on the housing that the thermocouple activates, which has a push valve at the bottom for lighting the burner after it has been turned off. It looks like I'll have to replace that whole piece.
Any idea where I can get one? I just replaced the thermocouple itself, so I can probably salvage that.
New Dometic Refer Installation k9s2go Refrigerators 9 07-26-2006 08:46 AM
How to turn off Dometic refer? Brian W Refrigerators 1 04-03-2006 10:34 AM
Dometic Refer Intermitent Richard Murphy Refrigerators 3 06-10-2004 05:45 PM
Dometic Refer question Mark Wiltrakis Refrigerators 5 04-03-2004 09:17 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
