09-18-2020, 03:14 PM
1968 28' Ambassador
Portland
, Oregon
Old Dometic - dare I plug this in?
I have an old rm760 that I'm trying to reuse in my vintage AS. The back components are pretty rusty (picture attached). I want to plug in the ac to see if that at least works. Would that be dangerous to do with the fridge components in this rusty state? Nothing seems rusted through but I'm weary that turning it in my cause a leak or maybe worse?
09-18-2020, 03:15 PM
1968 28' Ambassador
Portland
, Oregon
09-18-2020, 03:23 PM
1973 21' Globetrotter
Houston
That doesn't look too bad, where rust is concerned. I would say your bigger concern is that rats have built a nice flammable nest in the chimney of the cooling unit, and when you put juice to the electric heating element, things may get warm, nasty, smelly, and possibly fiery. So blow some compressed air down the chimney, and inspect the area around the heating element to make sure that there isn't anything flammable accumulated around it.
Note that it may take up to 24 hrs for you to notice cooling inside, and you want it to be sitting as level as possible. Also, check your rubber seals around the door. Last time I looked, replacements were pretty hard to come by for vintage fridges, so if yours are hard, compressed, cracked, or just generally unusable, then I wouldn't advise spending money on any other aspect of the fridge until you know what parts are available.
good luck!
09-18-2020, 04:06 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
If it doesn't get cold, it probably has lost it's ammonia. There used to be a company that could fix any tiny leaks & recharge the ammonia out in California. We had them fix our '64 about twenty years ago. I seem to recall their name was 'Cool Fun' or something like that...but I'm not sure they are still around.
The Vintage Airstream Website also has a list of RV Fridge guys that may be able to help if you need it. I don't know how updated that list is...but, there's even one in Oregon!
Good luck~
Shari
09-18-2020, 06:27 PM
1968 28' Ambassador
Portland
, Oregon
good luck!
Pardon my ignorance but could you tell me what part of this assembly is the chimney? Is it the tall skinny box to the right?
09-18-2020, 06:55 PM
1956 22' Safari
Conifer/Evergreen
You may find this helpful...it's a link to the 1968 Owner's Manual. It talks about the fridge starting on page 68.
Shari
09-18-2020, 09:15 PM
Houston
Yep, and follow the wires you see at about midpoint in the photo, because those go to the heating element.
09-21-2020, 03:28 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If you call Wick at RV Cool, rvcool.com, 1-800-515-6823. He can give you good advice or repair your unit. He has been in the Dometic refrigerator rejuvenation business for close to 25 years. He replaces all the plumbing with improved swirl tubing. No patch work all new. He did my unit 5 years ago and it is still working fine. He will do it at his shop or receive, repair and return yours to you by UPS.
guskmg
