Old 05-30-2023, 09:19 AM   #1
2023 30' International
Hanover , Pennsylvania
Norcold N10DC
I just received an E3 error code on my 2023 international. Looked at airstream supplied manual and they are useless. Looked at Norcold website and they too are useless. The only provided support between 1 and 4pm and airstream no longer provides phone support. I did notice that the error happened while the VictronConnect was doing an equalization and battery voltage was around 16 volts. Is this a concern?
Robert & Sharon Young
2023 International 30RBT
2023 Chevrolet Silverado 1500 Duramax
rlyoung1952 is offline   Reply With Quote
Old 05-30-2023, 10:53 AM   #2
2023 27' Flying Cloud
Greensboro , Arizona
I received the same error code when I was Boondocking and the batteries had dropped below adequate voltage. Once the batteries recharged sufficiently, the error code cleared. In the meantime, I turned off the fridge and kept it closed. (And you’re correct about the supplied manual. Useless.)
Jmwatson7 is offline   Reply With Quote
Old 05-30-2023, 11:44 AM   #3
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
I find the service manager at my dealer to be a good source of knowledge
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 05-30-2023, 11:50 AM   #4
2022 25' Flying Cloud
Vashon Island , Washington
When your fridge beeps and gives the E3 code go to your SeaLevel monitor and look at what your battery voltage is at.
A year into using my 2022 model mine started giving the E3 code. The first couple of times was while I was running the water pump while the furnace was running and a bunch of lights were on. I noticed that my battery voltage was indicating 11.8 volts. This was strange to me because I have a 400ah lithium bank were 90% full indicated by the battery shunt.
I checked the voltage at the batteries which was over 13 volts, and then checked the voltage at the fuse panel which showed 12 volts. Hmm? Turns out there was a loose connection behind the fuse panel on the Intellitec battery cutoff relay. I tightened the lug and now the SeaLevel monitor voltage matches the actual voltage of the batteries and no more E3 code.
So, you have low voltage; if your batteries are fully charged and you're still getting low voltage you probably have a loose connection somewhere.
AlIslander is offline   Reply With Quote
Old 05-31-2023, 06:42 AM   #5
Thanks but my voltage was 16 volts, batteries were being equalized. I have two AGM batteries but I am planning on purchasing 2 lithium batteries when I get home. This should not happen again since lithium batteries don't need equalization. In the mean time I have turned off equalization.
Norcold Model 624????? srgntpepper Refrigerators 2 06-11-2023 08:55 PM
Fridge: Dometic Vs. Norcold AYRSTRM2 Refrigerators 7 04-17-2006 10:57 AM
Norcold Blues RxRhino Refrigerators 3 01-25-2006 09:26 AM
Source for Heating Element foe Norcold 624 srgntpepper Refrigerators 2 05-11-2004 05:02 PM
Norcold g/e Refrigerator Recall FLguy8 Refrigerators 1 12-06-2002 12:58 PM
