Old 09-06-2019, 04:17 PM   #1
2017 20' Flying Cloud
Williamson County , Texas
Is there any reason to occasionally run refrigerator on gas?
I believe that the "gas" cycle components are simply the hermetically sealed system and heater. Would there be any long term reliability enhancement by occasionally running in this mode to "exercise" the system?
SYC2Vette is offline   Reply With Quote
Old 09-06-2019, 05:08 PM   #2
2018 27' Globetrotter
Vancouver Island , British Columbia
No where on the manual it says you have too. Having said that it would not hurt to make sure everything is working and do 5e maintenance as suggested in the manual
rintintin is offline   Reply With Quote
Old 09-06-2019, 05:35 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There's always the chance of "stuff" building up in the gas side of things. It's debatable if running the system blows stuff out or not.
Old 09-06-2019, 06:34 PM   #4
Retired.
. , At Large
It won't hurt. If nothing else, you'll be aware if a mud dauber builds a nest somewhere in the system.
Old 09-06-2019, 07:23 PM   #5
2018 25' Flying Cloud
Marana , Arizona
It’s a universal law that EVERYTHING needs to be worked to stay in shape. When we (likely everyone) are driving, the fridge is running off propane. While I can’t provide any specific data, I can tell you that I’ve read that operating off propane will give you lower temperatures in your freezer & fridge.
Rich & Mary
Marana, AZ
2018 25’ FC/FB
Zardoz is offline   Reply With Quote
Old 09-07-2019, 09:23 AM   #6
2015 22' FB Sport
Boothbay Harbor , Maine
For whatever reason, our refrigerator doesn't want to work on anything but gas. Nadda, zilch, zip on shore power. We think it gave up the ghost because last year on the last trip, it beeped 33 times every 3 minutes, which was it's way of saying "good bye".
dnas is offline   Reply With Quote
Old 09-07-2019, 10:47 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Use AC when at home to cool the refrig then switch to LP when Glamping - standard procedure.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 09-07-2019, 10:49 AM   #8
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
We spent a couple years full time before I retired and day-to-day and week-to-week routine made everything intentional, from when to fill the gas tank, planning the next stops, finding laundries, diners, and something interesting hiding in nowhere's ville. Also assured everything either broke or got checked just before it broke. Back in sticks and bricks and doing checks is so much easier to fall into the just after it broke category. Typically, we run fridge on gas when towing, so think I can pass on that one, but happy to "intentionally" think through if I needed to add it to my checklist.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 09-07-2019, 10:52 AM   #9
Sag Harbor , New York
Bingo!
Always a good idea to exercise each and every system from time to time IMO.
Old 09-07-2019, 03:38 PM   #10
CruizinDux's Avatar
Washington , Missouri
We run our refer on gas while otr, then back to ele in camp assuming doe hookups.
B
CruizinDux is offline   Reply With Quote
Old 09-08-2019, 04:55 PM   #11
CruizinDux's Avatar
Just to add/clarify, If I'm in storage for awhile, mid way to the next tip I often load the batts and exercise the WH, Furnace and refer. Also about a week before leaving more to simply make sure it's working vs giving it exercise. While OTR I often flip on the WH gas when in the CG since we usually go the FHU's route. Don't think it need scheduled exercise like a large genset...just want to know it's ready to go.
b
Old 09-08-2019, 08:29 PM   #12
Mike1997's Avatar
1998 36' Land Yacht Widebody
Reidsville , Georgia
Images: 14
Mine is a 3 way Dometic. Before I bought it, it set in a warehouse plugged in for a long time but everything worked. When I pulled out for the trip home, it switched to 12v just as it should. At home I plugged it in again. A month later got it ready for the first trip and again, if motor was not running it was plugged in......until I got to Key West!! There I had to boondock for 5 days while on a wait list for hookup. That's when I discovered it would not fire on propane. Cause was a faulty control board. Same issue occurred later with my furnace and water heater. They go bad with age.....however, its a easy fix.
I recommend turning it on as part of a maintenance check even if your not using it. That's how I also found discovered the DuoTherm t-stat would not start the furnace after new board was installed. $150 later, its working.
Mike1997 is offline   Reply With Quote
Old 09-09-2019, 07:16 AM   #13
2016 19' Flying Cloud
Newtown , Connecticut
We used the fridge on propane almost entirely for three weeks. Then refilled propane tanks. We were at 8000 ft elevation in Yellowstone. After that fridge would not stay on when in propane mode. When we got home, still would not run for more than 15 - 20 minutes on propane. Would go off and orange light would stay on. Got the burner serviced, but no apparent issues were found by the technician. Any suggestions on what we can do differently to avaiod this problem next time?
brundom is offline   Reply With Quote
Old 09-15-2019, 11:27 AM   #14
Popaugen65
1986 31' Sovereign
Lenoir City , Tennessee
Always run the gas occasionally. I rarely ran my furnace and over the years and condensation built up to the point that the gas valve to the furnace "froze" up. $$$ to repair. One would not anticipate condensation, but after prolonged shutdown during the winter (months), propane leakage out and air leakage in brings with it moisture into the lines. And no, I was never able to detect any propane leakage in the 15+ years I had the trailer.
popaugen65 is offline   Reply With Quote
Old 09-15-2019, 01:13 PM   #15
2017 28' International
Jim Falls , Wisconsin
I am of the mind one should test everything on a regular basis. As to the refrigerator I use LP while traveling. I will have to say I always switch from AC to LP long before we have to leave. From time to time the LP doesn’t start right up, and I have to bleed the line a bit by turning it off and then on a few times. I think you should also run the hot water heater on LP from time to time as well. Even run your inverter etc to make sure it works. Run the Heat Pumps as well. In fact really should do an all systems check on regular basis.
I’d rather know something doesn’t work at home rather than on the road.
Daquenzer is offline   Reply With Quote
Suburban Heater Blowing Cold Air occasionally Cody Madison Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-20-2014 03:39 PM
Is there any reason I shouldn't use a car antenna base like this for fm? Mixter Audio, Video & TV 9 02-12-2014 02:27 PM
Water heater goes out occasionally... steveirving Water Heaters, Filters & Pumps 12 10-24-2013 06:06 AM
Is there a reason for the smaller tanks in 28s farmerdave Fresh Water Systems 3 04-26-2012 07:09 AM
New electric jack only works occasionally Zmod Jacks, Stabilizers, Lifting and Leveling 3 06-14-2004 08:09 PM
